Spark Check Result, Constant Current Flow
Old Mar 16, 2025 | 11:53 AM
  #61
diggerrigger's Avatar
diggerrigger
Theorizing: The coil can only fire when the (-) lead is grounded. That lead goes to the ICM and tach only (why I have wanted to disconnect the tach). But my mind keeps telling me that probably the ICM is triggering the grounding. Whether the frequency is 100 Hz or 67k Hz it's still extremely fast. and consistent. Maybe a processor in the ICM getting conflicting commands.
I'm going to order what is advertised as a Ford ICM from a Ford dealership Internet website tomorrow regardless. $85 with discount. Hopefully I get to speak with a competent counter salesman.
  #62
AuroraGirl's Avatar
AuroraGirl
Originally Posted by diggerrigger
Some more background on the parts cannon diagnostics by the previous owner. I remind everyone that I consider the PO an able mechanic. Like most of us, he is likely much better at mechanical things than electronics.
Hurt my feelings when I became aware that he had purchased a rebuilt PCM off the net and paid, I believe, over $700. My '86 truck's ECM was listed at Advanced for $150. The PO was pretty sure he was dealing with an able and competent supplier. I asked if his supplier had asked about transmission and calibration code. PO confirmed he had. But a few days later a120 pin unit showed up.
I knew he had sent it back, exchanging for a different unit. I didn't realize until the other day that this truck was a 60 pin. Remember, I was pleasantly surprised because I had a 60 pin breakout box.
What I'm getting at is maybe the PO bought from a disreputable vendor. Maybe the PCM is incorrect and junk to boot.
I know the truck doesn't always shift gears correctly so I wonder if there is a E4OD vs 4R70W issue. My truck having the latter. Were '95s mostly 4R70W equipped?
I also know the PO's wife is the one who went to AutoZone to pick up the first ICM (actually, the truck was her's, a hand me down from her father)
a 4r70w is going to be different than e4od for purposes of how its programmed
but its also electronic , so theres that
Old Mar 16, 2025 | 11:54 AM
  #63
AuroraGirl's Avatar
AuroraGirl
a ground path for a coil when its magnetic field collapses produces spark
Old Mar 16, 2025 | 11:56 AM
  #64
AuroraGirl's Avatar
AuroraGirl
Before I submit this morning's findings, a quick acknowledgement of @AuroraGirl 's contribution s. Thanks for pointing to Steve83's at Supermotors. Tons of information there on OBS trucks and Broncos.
Not sure if you were suggesting I check the wiring to insure my truck has CCD wiring or if that was pasted content from Steve83. Regardless, I can confirm that the truck is CCD. Still don't know how to determine if I have the correct ICM.
And the problem with most all the ICM testing on the truck is it is aimed at diagnosing a no or intermittent spark. Problems I run into on factory step by step (fan of step by step) is three steps in and you need a dealer proprietary test harness. Then I'm left trying to comprehend exactly what they are actually testing and then figure a work around using t-pins and back probing connectors.
On to today's surprises. When setting up to test the key switch to start with S-wire disconnected I needed to get my spark tester where I could see it from the driver's seat. I substituted a longer plug wire in place of the coil wire. No current flow even if I tightened the tool gap considerably. Coil wire= 7000 ohms, plug wire= 14k ohms.
Not sure if I reported or even checked this before but with current flowing,when the coil (-) is grounded the current stops. Unground and it starts again... "Most" times. If I poke at the coil (-) I can get the current to stay off... Sometimes.Note, grounding using test light.Bizarre.
Other suggestions followed up on. The PIP and SPOUT both deliver voltage pulse you would expect, engine running. Back probed at ICM connector
Other unrelated news. We had a heck of a storm overnight and I was disappointed to see the PCM connector all wet this morning. What a stupid set-up. Getting ready to storm again, gotta go
I meant since this truck is new to you, if the engine harness were from a pre 94 it would be wired for a push start, but the connector would be the same appearance.
also groundign the frame of the coil making it stop sounds like its a bad coil to me, personally
Old Mar 16, 2025 | 11:59 AM
  #65
AuroraGirl's Avatar
AuroraGirl
The coil connectors are dirty but corrosion free. I've unplugged and replugged many times during this quest. I'm sure of good connections.
The grounds? I cleaned and shined every ground I could find except I haven't serviced the main cable connections at frame and block. I should. I have checked for non harness ground problems as well. Pick up module to distributor housing. Housing to block. Everything does show <1 ohm resistance back to the battery (-)
I would like to think I have the grounds covered but I can't be sure. Can you suggest where to look for any of those stealth, not easy to find ground points?
I can put my hand on every ground wire, splice, connector and ground lug on my '86 EFI... Blindfolded!
i dont think its your failure, but you can add an additional ground to the engine, so you dont have to remove the one on the engine block, by using the rear of the alternator (theres a threaded hole ) and a metric bolt
Old Mar 16, 2025 | 12:46 PM
  #66
diggerrigger
Not the coil frame but the (-) terminal
Currently, the new Motorcraft coil is mounted
Old Mar 16, 2025 | 01:32 PM
  #67
diggerrigger
Originally Posted by Soup bean
I put this on every electrical connection I make. (Whatever brand you want).
I use this.
It's Alcoa EJC, Electrical Joint Compound. Dad brought this tube home from work in the 1960s.. At the smelter they used this to bolt up the sacrificial anodes in the aluminum pots
Old Mar 16, 2025 | 02:45 PM
  #68
diggerrigger
Is this capacitor a replacement for my truck s original?
Old Mar 16, 2025 | 02:54 PM
  #69
diggerrigger
@Prototypemech
Do you have a trick to unpin the terminal from the connector? Can the lock tab be disengaged from the front?
Also, just cold and windy now. Wet is over. So, after reading back through what I've done and not done, l checked for the offending current with key on, distributor unplugged. No current.
Old Mar 16, 2025 | 03:44 PM
  #70
Prototypemech's Avatar
Prototypemech
@Prototypemech
No, I don't remember which way the de-pinning tool needs to be inserted. Interesting observation with the distributor disconnected. Without power to the PIP, it's obviously not gunna work, so I wouldn't expect any current. How much current are you seeing with the Distributor plugged in?
The PIP circuit also feeds into the ECU so it can modulate the spark output via the SPOUT wire, but it should be just an input circuit (listening), not a output circuit (signaling). Just just for funsies, you may wanna hook everything back up and disconnect the ECU to see if the high voltage still exist at the coil with the key-on. I don't expect the ECU connection will make any difference.
Old Mar 16, 2025 | 03:56 PM
  #71
diggerrigger
I don't recall if I checked with the PCM only disconnected. On the list. This list of things to do? It should probably be done with a pen and paper.
Old Mar 16, 2025 | 10:18 PM
  #72
AuroraGirl's Avatar
AuroraGirl
yes that’s why I sent it
Old Mar 17, 2025 | 04:03 PM
  #73
diggerrigger
@Prototypemech
@Prototypemech
The seal on the back pops out easily. In front the red tab also easily pops out. Insert the pick sliding it along the terminal until you feel bottom. Pick that bottom away from the terminal. Bam!
Picked up a practice connector at the you pull this morning.
Found a 88 F150 5.0 and a 88 Crown Vic 5.0
Old Mar 17, 2025 | 04:28 PM
  #74
diggerrigger
De-pin or cut the PIP wire.
Interesting development. With PIP de-pinned at ICM the current flow becomes rhythmically intermittent. Could not replicate on subsequent tests. went full current flow instesd. On/ off cycle a few times per second. Re plug the PIP and it's back to a smooth, steady stream.
With the PCM unplugged we still get the steady current flow. Thinking about that now
Old Mar 17, 2025 | 04:40 PM
  #75
Prototypemech
Interesting development. With PIP de-pinned at ICM the current flow becomes rhythmically intermittent. On/ off cycle a few times per second. Re plug the PIP and it's back to a smooth, steady stream.
What about PIP depinned, ECU unplugged, and SPOUT disconnected. That removed all input into the ICM. You should have no current flow.
Dave R
