HELP! 2022 F250 Electrical problems
Old Mar 12, 2025 | 09:41 AM
rayaljets's Avatar
rayaljets
1st Gear
I purchased a 2022 F250 XL from a salvage lot. It had been rear ended but everything from the cab forward is fine and I wanted a flatbed on it anyway. Got the frame straightened and a new rear axle installed and its ready for the flatbed. I am having a few electrical problems that I could use some help with.
1. The radio functions fine but will only respond to the steering wheel controls. All of the dash functions are inoperable.
2. The climate control panel is inoperable. The buttons are backlight and I've checked all appropriate fuses.
3. The driver side window control switches don't work for either the driver or passenger windows. The passenger window works fine from the passenger side.
Any help you guys can give me would be appreciated.
Thanks,
Ray
Old Mar 12, 2025 | 10:17 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Maybe a body control module issue.
You'd need to get a dealer level scan tool on it to see what everything is doing.
Old Mar 12, 2025 | 12:56 PM
longhaultransport's Avatar
longhaultransport
Great idea, CANbus.
Just kidding, sort of.
Old Mar 12, 2025 | 09:49 PM
Tom S's Avatar
Tom S
My first estimate is what wiring got damaged in the collision that might be crashing the communications network.
Old Mar 13, 2025 | 07:15 AM
HorizontalHunter's Avatar
HorizontalHunter
This. Ford trucks are known to have wiring fatigue in the door wiring harness.
Bob
Old Mar 13, 2025 | 09:47 AM
Mike Bartlett's Avatar
Mike Bartlett
First thing is figure these problems out before adding a new bed and additional electrical items, lights, sensors, etc. As always the batteries are crucial for proper function of anything in these trucks don’t just assume their good or new enough, double check the connections are tight, clean and securely attached. Some of this is probably related to the accident so check all wiring and connectors closely for damage.
just my 2-cents.
Good luck,
Mike
Old Mar 14, 2025 | 11:20 AM
KH338's Avatar
KH338
Make sure all the wiring is complete for the flat bed before troubleshooting. I’ve swapped on a flat end and had unusual issues until everything was hooked back up.
JackalAR
Jun 9, 2025 05:49 PM
trenton casa
Jan 6, 2025 09:46 AM
Westexpackfan
Apr 11, 2022 09:35 AM
txnese
Oct 3, 2021 07:02 PM
F250obsF350owner
Feb 20, 2021 08:59 PM
