2007 f250 window problems
Old Dec 31, 2024 | 02:49 PM
trenton casa's Avatar
trenton casa
4wd Low
i bought a 6.0 f250 and the windows will not work. i replaced the drivers side switch panel with a working one and fuse 601 has 12v on both sides. i’m stuck and can’t figure out why all the windows won’t work
Old Jan 2, 2025 | 12:50 PM
runthatjunk's Avatar
runthatjunk
Could be instrument cluster or fuse box. Here's an 04, may or may not help
May be power to switch is broke at the door to cab junction
Old Jan 2, 2025 | 02:52 PM
kbeefy's Avatar
kbeefy
Do the power locks or the switch illumination work?
None of the windows work, correct? I think if you have power at 601 the instrument cluster and the delay relay are operating correctly.
Take a look at the threshold wiring in the drivers door jam. Try actuating the windows with the door open, or swinging it thru it's travel.
Those wires fatigue and break pretty often.
Old Jan 4, 2025 | 08:22 PM
trenton casa
4wd Low
I put in a working instrument cluster and they still did not work, i will try to use the windows while the door is open right now
Old Jan 6, 2025 | 09:46 AM
BryanStein's Avatar
BryanStein
I believe al the windows are powered through the driver side controls. I had an issue with my right rear, and it was a cut wire at the drivers door hinge. Not much room to find it, much less repair it, but I got it done.
So check for a cut or short in the wires running through the hinge region to the drivers control panel.
pick1967
Electrical Systems/Wiring
Apr 21, 2022 09:58 PM
Westexpackfan
Apr 11, 2022 09:35 AM
6 or 10
Aug 24, 2015 08:02 PM
BIGIRONMAN9
Apr 30, 2011 08:32 PM
Cock_Diesel
Feb 4, 2004 08:49 PM
