straight axle
Old Dec 4, 2003 | 02:55 PM
powerstation's Avatar
powerstation
straight axle
Has anyone done a straight axle conversion on a ranger before? I'm thinking of doing on my 89 4x4. I'v got very different opinions on this and was wondering if anyone has done this. Any help or ideas/opinions on this would be great! Thanks!
Old Dec 4, 2003 | 07:30 PM
Dealford's Avatar
Dealford
If you could find an original Bronco(67ish) you could transplant the 9" axles from that.
Old Dec 4, 2003 | 08:18 PM
powerstation
would they be the same size ( or close ) or would I have to cut them down to meke them fit?
Old Dec 5, 2003 | 06:43 AM
774x4's Avatar
774x4
I've done it. It really isn't hard at all. Just find an early bronco preferably '74 and up because they come with Dana 44 front instead of the dana 30 which is really weak. Use radius arm drop brackets from a 78 or 79 bronco, use 3.5" early bronco lift springs, fab up a track bar mount and that is about it. You can swap in a 9" also but I had already swapped in a 8.8 so I kept it.
Here is a pic:
Old Dec 5, 2003 | 11:11 AM
powerstation
774x4...
did you have to cut that axle down or was it the same size?
Old Dec 5, 2003 | 11:24 AM
774x4's Avatar
774x4
The axle is a couple of inches wider, I forgot exactly what the dimensions were, but you don't have to cut it down at all. The springs drop right into the original coil buckets with minor modification to make them seat right.
Old Dec 5, 2003 | 11:59 AM
powerstation
thanks for the help!
crowbar_96854
1978 - 1996 Big Bronco
23
Jun 20, 2011 10:10 PM
vaden66
Dec 21, 2010 12:51 AM
kiastuff
Mar 20, 2009 09:21 PM
Dre82s
May 21, 2008 07:08 PM
fords_forlife
Offroad & 4x4
Apr 29, 2006 11:59 AM
