Best shorter antenna
Old Mar 6, 2025 | 03:29 PM
Cliffblue's Avatar
Cliffblue
2020 XLT screw. My OEM antenna hits my top garage door plate. I installed an identical 2” shorter one that used a stud to mount. The drive through car wash bent the antenna and stud. I reinstalled the OEM antenna for now. I do listen to local AM/FM broadcast. Any suggestions for something shorter that works good? Thanks
Old Mar 6, 2025 | 04:32 PM
Beechkid's Avatar
Beechkid
IMHO, I would unscrew the oem unit prior to entering the carwash... or modify it so it will come off easily.
Old Mar 7, 2025 | 12:47 AM
JKBrad's Avatar
JKBrad
I used some Vise Grips to pull the ball of the end of the OEM antenna, cut 4” off with a bolt cutter, then put the ball back on with JB Weld.
Old Mar 7, 2025 | 09:36 AM
jr105's Avatar
jr105
I just bought a shorty antenna at a parts chain store and it works fine. The reception range may be very slightly less.
Old Mar 7, 2025 | 10:08 AM
GlueGuy's Avatar
GlueGuy
I got a shorty antenna through Amazon. Look for one with a loading coil.
RTT
Mar 27, 2024 08:24 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
15
Jan 9, 2017 11:30 AM
jcsv99
2004 - 2008 F150
May 9, 2007 07:06 AM
97F250XLT
Mar 5, 2007 10:29 PM
fredd
Oct 18, 2004 10:22 AM
