Power Master alternators
Old Mar 5, 2025 | 05:21 PM
MDHunter's Avatar
MDHunter
Power Master starters get lots of positive reviews on this site, any feedback on their alternators?
Mike
Old Mar 5, 2025 | 06:56 PM
BWST's Avatar
BWST
Got Data?
I was trying to find a good price on one to try out, but no luck so far. Considering the 6.0 Bosch at the moment because I only need 110-135A. It looks like the 48478 is a 200A unit. Anyone find a smaller output one?
Powermaster 48478 Powermaster Race Alternators | Summit Racing
Old Mar 5, 2025 | 07:02 PM
MDHunter's Avatar
MDHunter
I was looking at the 47796 rated at 155a.
Old Mar 5, 2025 | 07:25 PM
BWST's Avatar
BWST
Got Data?
Ok, that helps. Still priced a bit high. I see a 120A version on Thoroughbred's site, 7796, for $254. Still high relative to a Bosch 6.0 AL7606N.
Powermaster 47796 Heavy Duty 155 AMP Alternator 1999-2003 7.3L Ford Powerstroke | Thoroughbred Diesel
Amazon.com: BOSCH AL7606N Premium 100% New Alternator - Compatible with Select Ford E-450 Super Duty, F-450 Super Duty, F-550 Super Duty; 135 Amp : Automotive Amazon.com: BOSCH AL7606N Premium 100% New Alternator - Compatible with Select Ford E-450 Super Duty, F-450 Super Duty, F-550 Super Duty; 135 Amp : Automotive
Noted Rockauto has a "Famous Brand" wholesale closeout alternator with a similar part number as that Powermaster 120A version, 7796A reman, for $74.99.
Old Mar 6, 2025 | 05:58 PM
Hellraiser456's Avatar
Hellraiser456
Im running the bosch. Used a large file to modify the alt bracket.
It gets a beating with the short commute and cold winters, and i use cheap batteries. Seems to be holding up but is also only a year old (survived basically 2 winters though). Unless you are running something like a winch, it keeps the voltages safe (around 11.7v after a fesh cold start) for the glow plugs, and offers a little more jam when above idle. I used the pulley it came with, but i know some switch the pulley.
Old Mar 6, 2025 | 08:23 PM
John in OkieLand's Avatar
John in OkieLand
Expensive, but well worth it, MechMan
Old Mar 7, 2025 | 07:48 AM
MDHunter's Avatar
MDHunter
John, was the mechman a drop in, or did you have to do any tweaking to the bracket?
Old Mar 7, 2025 | 09:21 AM
John in OkieLand
drop in, bolt it down
you have to tell MechMan which motor you have.
Old Mar 7, 2025 | 09:33 AM
brokestroke's Avatar
brokestroke
What is the reasoning behind such a large alternator? My plow truck has an OEM unit and have never had any charging/dimming issues or flat batteries after plowing for hours at low RPM.
Old Mar 8, 2025 | 08:34 AM
BWST's Avatar
BWST
Got Data?
I was planning to use the extra capacity from the dual OEM alternators on my rig to charge the trailer battery bank through larger gauge wires and a DC to DC converter.
Like you said, the extra capacity is not needed in many applications where there’s enough time to bring the batteries back up after starting,or the loads are not over the alternators capacity for very long. Funny, I thought plowing, especially at night with the extra lights and hydraulics, might benefit from extra alternator capacity.
Interested to hear how others are using the additional amps.
Old Mar 8, 2025 | 10:11 AM
Big Horn 2's Avatar
Big Horn 2
Like Brokestroke, I use a 17,500 lb winch (which by the way all electric DC winches have a duty cycle) lot of light accessorie, and a DC to DC charger…… my 110A OEM alternator does the job nicely.
Even running extra amperage will not necessarily make a DC to DC charger run at full capacity. There are other variable and safeguards designed into the charger by the manufacturers, amount of external heat, air flow of the heat sink, phase of charging, wire resistance (incoming voltage - not amps), etc. that effect at how many amps it charges the house battery with.
And then there’s the Ford engineered issue of glowplug reliability and why they specified the 110A alternators on our 7.3 trucks, which goes way down the rabbit hole.
Old Mar 10, 2025 | 01:09 AM
INFRNL's Avatar
INFRNL
I do not recall which Bosch I have but it's drop in and has worked extremely well for the past 12 yrs. I did run a 400A Mechman for nearly a yr until it failed. It was covered under warranty and I haven't reinstalled it yet.
I just swapped out to smaller injectors and tested my glow plugs, they are still great; so signs of issues and ohm out to 0.5 ohms. I did not change how I start my truck as John does. It does crank slightly longer to start compared to using the bosch for whatever reason. Glow plugs have been installed for the past 3-4 yrs.
The thing about aftermarket alt's is the ability to have higher amperage output at idle. OEM/ bosch is very limited unless idled up.
I'd like to think Powermaster, Mechman, and Leece Neville would all be great choices for upgraded options. Otherwise Bosch is extremely reliable
Old Mar 10, 2025 | 01:22 AM
Big Horn 2's Avatar
Big Horn 2
^^^^^^ that’s a really good point about the stock alternators’ output at idle. I do use my high idle tune when running my winch due to the added load.
MDHunter
23
Jan 31, 2025 06:02 PM
Jeeptrix
17
Feb 8, 2023 07:50 AM
rsdjcarter
Nov 19, 2008 03:32 AM
wiseguy50
Mar 28, 2005 06:35 AM
