Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
Weird engine power loss
Old Mar 5, 2025 | 02:12 PM
mfee2079's Avatar
mfee2079
4th Gear
I have a 97 Fleetwood pace arrow vision on a Ford F53 chassis. Engine is the 460 gas.
I'm getting a lot of dieseling and after about 2 hours of driving the engine looses power. I can't get over 2k rpms without the engine bucking and the check engine light comes on (OBD-1) If I stop, turn the engine off, wait a minute than start it back up all is well again though for how long cares from time to time.
I know the timing is off as when I got it the hold down bolt was loose, i set it as best i can but because of the dog house design i cant see the timing marks any advice.on how to rectify that issue would also help.
like I said this, even though its a 97 is still OBD 1.
Fuel tank and pump are new 80 gallon tank and fomoco sourced in tank pump (2023)
mileage is 33,576
Old Mar 6, 2025 | 07:34 PM
85e150's Avatar
85e150
Did it do this before you replaced the tank and pump?
I moved your other thread to the engine forum.
https://www.ford-trucks.com/forums/1...ower-loss.html
Old Mar 6, 2025 | 10:09 PM
mfee2079's Avatar
mfee2079
4th Gear
The owner I bought it from says it did and he was told it was the fuel.pump so he replaced both.
Old Mar 7, 2025 | 09:19 AM
HydroDog's Avatar
HydroDog
Well I’m not the expert but since it resets it self when turned off I would guess it’s electrical.
I suppose there could be the outside chance that your getting a vacuum in the fuel system.
That would mean under that condition if you opened the filler cap the problem would go away but I would have thought that someone replaced the full cap with the new tank and pump. .
If it was mine, I would be looking at the ignition coil, electronic ignition module or a ECU going bad. Being a van chassis, that distributor module and coil are going to get hot. In the 87-96 trucks the capacitors go bad in the ECU and create running issues.
flashgordon_F250
May 4, 2023 08:42 AM
MkeMike
2015 - 2020 F150
62
Oct 29, 2019 12:39 PM
MasterPepe
Feb 5, 2017 02:49 AM
fordmanswife
19
Oct 22, 2005 12:57 PM
