TB coolant line removal
Old Mar 3, 2025 | 10:22 AM
Sycostang67's Avatar
Sycostang67
Has anyone deleted the coolant lines that run through the throttle body, working on a 93 5.0. The preformed lines aren’t in the best shape and it would be easier to just eliminate them. I live in Idaho and the low temps are usually in the 30’s with occasional dips into the teens.
Old Mar 3, 2025 | 10:37 AM
Hit Man X's Avatar
Hit Man X
Yes I have around the year '00. No ill issues.
I used a pipe plug down low and a fresh heater hose on mine. There are a few routings available, so just eyeball it and knock it out.
Done for ease of service and less places to leak, not for 'power" gains.
Old Mar 3, 2025 | 11:21 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Preformed lines?
Old Mar 3, 2025 | 11:23 AM
Hit Man X's Avatar
Hit Man X
Me? I cannot remember as it was so long ago.
Old Mar 3, 2025 | 11:41 AM
Sycostang67
Preformed lines?
This truck has a preformed metal line that runs along the top of the radiator where it crimps into a rubber hose that runs over to the tb. I used to have a 95 F150 with a 5.0 and don’t remember it having that line. It looks totally factory though.
Old Mar 3, 2025 | 12:22 PM
Jim_K's Avatar
Jim_K
I deleted this from my '92 F150 about 5 years ago, and so far- no issues.
Old Mar 3, 2025 | 02:52 PM
Mudsport96's Avatar
Mudsport96
Unhooked mine about 150k miles ago. No issues.
Old Mar 3, 2025 | 03:28 PM
My4Fordtrucks
Ah. I believe that is only on hd cooling package. I added that tubing to my trucks. If you did not have that then the top hose from the throttle body teed into the heater hose.
Living where you do, I would keep it but you can bypass the throttle body if you want.
Old Mar 4, 2025 | 04:57 AM
manicmechanic007's Avatar
manicmechanic007
I fix and replace the hoses regularly
Your truck needs that EFE (early fuel evaporation I think they called it in screwell)
EFE, look it up if you want
I'm in Utah and we need it when temps drop below 30F
Same function as the old heat risers on carbureted vehicles
I would damn sure keep it in Idaho
But
Your truck will run fine without it in the winter, and maybe even run better in the hot summer without it
Old Mar 4, 2025 | 08:30 AM
1Butcher's Avatar
1Butcher
I swear my 5.8L CA engine had the line start at the radiator, through the throttle body, and back to the intake manifold. The radiator line is needed for bleeding. I routed the hose so it does not go to the throttle.
Highly unlikely it will effect anything, but that is just my thought.
Old Mar 4, 2025 | 09:05 AM
My4Fordtrucks
I guess that was just a description of the routing? Coolant flow is the other direction.
Old Mar 4, 2025 | 09:11 AM
1Butcher's Avatar
1Butcher
Yes, just how the hose/lines route, not flow.
As far as I am concerned, you need that hose hooked up, go ahead and bypass the throttle, but do block/remove the hose, it helps bleed the air out of the system.
Old Mar 4, 2025 | 09:16 AM
My4Fordtrucks
Which hose do you need?
Kruse
Sep 9, 2022 10:26 PM
Zacbkennedy
Feb 20, 2017 11:31 AM
wendell borror
1983 - 2012 Ranger & B-Series
23
Mar 26, 2006 01:40 PM
Black Ranger
Nov 26, 2003 07:17 PM
HOpowerstroke
Oct 27, 2003 06:04 PM
