"91 150 Starter Relay...?
Old Mar 3, 2025 | 10:22 PM
nuttruck's Avatar
nuttruck
Trailering
So my second replacement solenoid(fender mounted) is again bad? no start relay(six or seven pin cube) involved at all?
Old Mar 3, 2025 | 10:33 PM
Soup bean's Avatar
Soup bean
Disconnect the cable going to the starter, from the large stud on the fender mounted starter relay.
Set your volt meter up to read DC volts, with one lead on the battery negative and the other lead to the large stud where the starter cable was connected.
Disconnect the small gauge wire from the "S" terminal at the starter relay.
Put on safety glasses or a face shield.
Using one conductor of a set of jumper cables, use red to keep it simple, connect one red clamp to the battery positive post, and use the other red clamp to touch the "S" terminal stud.
When the relay closes, 12 volts should be present at the large stud where the starter cable was connected.
Have the truck in park or out of gear, have the parking brake set and wheels chocked.
Old Mar 3, 2025 | 10:41 PM
Soup bean's Avatar
Soup bean
Be methodical, and test for voltage as described above.
No, there's no "cube" relay involved with powering the starter.
The battery terminals, positive and negative battery cables, and their connections need to be clean and reasonably tight; at the fender relay, at the engine block and at the starter.
Old Mar 3, 2025 | 10:47 PM
nuttruck's Avatar
nuttruck
Trailering
Understood. Now if the meter shows something less than 12v or nothing at all this indicates a bad solenoid? What about the start relay, the black seven pin cube?
Old Mar 4, 2025 | 03:58 AM
manicmechanic007's Avatar
manicmechanic007
Black 7 pin cube?
Post a pic
Old Mar 4, 2025 | 04:22 AM
tjc transport's Avatar
tjc transport
i ain't rite
the parts store counter monkey does not know his asterisk form a hole in the ground. your truck does not have one of them in the starter circuit no matter what his computer says.
with volt meter, black wire on ground cable, and red wire on the small wire going into the starter relay, have someone turn the key to start. you should see 12 volts to the starter relay. if there is 12 volts there, either the relay is bad, or the ground is bad.
Old Mar 5, 2025 | 09:58 AM
dremtofford's Avatar
dremtofford
91 150 starter relay
Could it be the neutral safety switch.or if it is a manual a clutch switch. Get a evtm it is valuable as it has wiring diagrams and trouble shooting charts.
Old Mar 5, 2025 | 10:04 AM
tjc transport
i ain't rite
if you have battery voltage at the starter terminal on the relay, the NSS is good
Old Mar 6, 2025 | 10:25 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by Hit Man X
Anyone added extra ground from noid back to battery, just to CYA?
No solenoid on the starter, just on the passenger side fender. The solenoid on the fender produces only a "click" when key turned to start, no turn over. When solenoid jumped with screwdriver engine fires right up as it should. So, if solenoid jump results in solid turnover and fire, key turn prodices very audible click from solenoid, what is left? all connections cleaned, solid ground, nothing left...except replace start relay? as in the little black cube with six or seven flat pins on the bottom, but where does it plug in???
Its not a solenoid if its the modern type black plastic body, with 2 studs. Its a relay. The solenoid on the starter is still there.
The old type was a solenoid , and is worse than the modern type. Can be upgraded anytime
This adds confusion because there will also be a starter relay in the relay box im pretty sure
FordLou
1997 - 2003 F150
22
Nov 1, 2019 06:39 PM
Scott in TX
Jul 28, 2019 10:55 AM
dan6915
Jun 11, 2015 10:30 AM
robbyf250
Aug 16, 2010 10:18 PM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
May 14, 2004 08:52 PM
