Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
2014 Edge water pump etc.......
Old Feb 25, 2025 | 06:46 PM
Eric Kropp's Avatar
Eric Kropp
So.....hopefully not a long story long. I had the water pump along with the timing chain replaced due to weepage. Not real happy with the shop that did the work as they got a valve cover gasket out of place and had a pretty good leak. They fixed that. Then the water pump started leaking out of the seal on the shaft......They replaced the water pump. Now whenever I'm heading up hill and make a right hand turn I smell oil real strong inside the car. So of course I took it back and they can't find a leak.....and there is no drips on the ground. I looked every where and I can't see a leak......so I drove it a bit today and sure enough, every uphill right hand turn strong oil smell in the car.......anyone know where the intake is that draws air into the cab?
fordbozo
6.4L Power Stroke Diesel
Jan 19, 2025 10:41 AM
bbsitum
2009 - 2014 F150
Jan 9, 2022 07:11 AM
dearborntruck
2009 - 2014 F150
Feb 14, 2021 07:27 PM
1L243
24
Sep 29, 2012 09:52 AM
ghostwhite
Dec 21, 2010 07:48 AM
