Governed carb Trouble!
the only thing I have done is a few years ago I installed a mechanical oil pressure gauge and last week I seen that the old sending unit was leaking on the back side of the motor. so I removed it. anyone know if that stupid thing has anything to do with the Governor?
I have only generic advice: on Ref. 9507 check that the vacuum line is connected to the hose barb, and that the electrical connector is still plugged in. Based on what I see of the 9B570 image, you can pull the steel side cover 9981 off and verify that there isn't a mechanical issue.
If it works similar to the older pneumatic setup, the spring 9980 pulls on the throttle shaft and wants to open it. It pulls pretty hard -- it does not have a lot of leverage, and it's only about 1.25" long. With the engine OFF and the accel pedal depressed, the throttle shaft should rotate to open, via that spring. If it doesn't, make certain that there is not a mechanical issue, like a corroded throttle shaft. It should move very freely, because it's a small spring with little leverage. Don't try to replace the spring with a stiffer one, fix the mechanical issue.
Also, if that spring is disconnected, the throttle will not want to open. It will, a little, but only via engine vacuum acting on the throttle plate, which isn't much as it's fairly balanced.
On the older system, the diaphragm pulls against the spring to close the throttle, regardless of what you do with the accelerator. Put another way, the accelerator pedal isn't connected to the throttle plate at all, it (the accel linkage return spring, actually) merely acts against that little spring 9980. Lack of vacuum means it will not govern, so I would not expect a hose disconnected to give a "won't rev" symptom. But I honestly don't know how this system work, and what the electronic part does. There is an electronic box that it interfaces with, but the whole thing is crude by today's standards and it doesn't do a whole lot, it's not a computer, IIRC it's analog.
Perhaps someone with experience with this later electronic governor will add more info. I don't have the Ford Shop Manual for '78-79, so I can't add more, but if you're going to work on your own truck, having the manual is a good investment. Reverse-engineering stuff of that era isn't easy; documentation helps a lot.
clear as blue mud ?
If there's a mechanical issue with the primary throttle shaft -- if it's hard to move, for example -- then the little spring (ref 5580) can't pull the throttle open, and nothing you do with the accel pedal will fix that.
