Cruise controll donors for my truck?
on
1 Post
I want to add cruise control to my '79 F250.
My questions are, what years will work when I am looking for a donor vehicle? Will the parts off a car work? What are the parts I will need to take from the donor should I find the right one? I want it to look like factory installed when I am done.
I don't think a car system will work. You will need the steering wheel with horn buttons, turn signal switch, wiring harness, control box, brake pedal, vacuum brake booster, brake mounted switch, throttle servo, vacuum reservoir (looks like a coffe can), vacuum check valve.
I did it myself and it does work and is not difficult to install. Just take this list with you when you go to the salvage yard.
You need to verify what you have first.
Here is the parts swap list.
Cruise control swap
Parts required listing.
Cruise Contol module (Underdash)
Cruise Control wiring (Underdash)
Cruise Contol actuating device on Intake
(Carb linkage chain,bracketry,Vacuum pod)
Vacuum actuation device harness
Vacuum Canister and hose to rear of intake.
Brake Booster FT-38 ,or FT-43
Brake Pedal & Pedal Assembly
Cruise Control shutoff switch
Horn relay & wiring
Horn Pad with Switches
Cruise control swap
Horn relay & wiring
on
1 Post
Thanks 76 and Mil1ion. I guess I should have also said I have a 4 speed trany. In 79 I bought a new Mustang that had a manual trany and cruise. It had a switch on the clutch to kill the cruise when it was pushed in.
Will the parts from a newer Bronco or truck work? Mainly the stearing wheel and wiring? I don't mind if the stearing wheel is not from a 79, as long as it is from a Ford. I have considered an after market add on, but don't like the looks and have never heard good reports on them.
