'47 Jail Bar Van
The facebook link won't post but this is from the seller's description:
This is a really rare Ford curbside van with the jailbar front end.One year only.I installed brand new windshields and rubber.I've been through this thing in and out. All new brakes rebuild drive shaft, new master ,new wheel cylinders. rebuilt rims and tires all bias plies tires Firestone. Put an aftermarket hooga horn. I installed aftermarket gauges. I did not rebuild the factory gauges, only the speedo. Works great along with the new speeda cable. Went through and put all brand new wiring. All new lights rebuilt the deck in the back raptor unber coated it. Brand new aluminum radiator.4 speed none syncrow. Flatheads straight six 3.7 L. Runs really good and drives well. Only does about 50 mph Max. This is like an old Jeepers creepers truck. Pretty much use it for whatever. It is registered in my name pink slip in hand. I've had it going on 3 years. Gas tank has been cleaned as best as we can. Is there original tank. I do have to change the filters out once in awhile.needs more glass!
