Ok my problem was I couldn't get the new serpentine belt to go on because the pulley was too big. So if I buy one that says it works with the 4.9, 5.0, 5.8 I should receive the smaller pulley right? But if I buy one that says it works for the 4.9 and 7.5 I'll be back in the same boat with the bigger pulley I would assume?
Im not sure if the 4.9 and 7.5 had the same pulley before the 94 changeover I mentioned as the 5.8 or 5.0
A/C - Increased Refrigerant Charge
Article No. 94-19-20
09/21/94
AIR CONDITIONING - INCREASED REFRIGERANT CHARGE - VEHICLES BUILT THROUGH 8/30/94
ISSUE: Ford Climate Control Division has increased the refrigerant charge in the subject vehicles from 2 lbs. 1 oz. to 2 lbs. 6 ozs. Also 94-97 trucks call for 2 oz of oil additional over the service data.
ACTION: When service to the A/C system is required, recharge the A/C system with 2 lbs. 6 oz. of R-134a. Make the necessary corrections to the 1994-95 Service Manuals, pages 12-00-35, 12-03A-58 for 1994 and 12-00-39, 12-03A-56 for 1995.
[img alt="Where does this red one plug into? I looked on the back of the compressor and hose manifold no plugs or any electrical.
Its the high pressure switch i believe correct me if im wrong. "]https://cimg0.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/227x297/20250217_181614_683e5172252c8a47ccf915eee832bb6bb3 2e33bf_cea1dde84a1ac4b6c4700d83d051667b114af9a2.jp g[/img] Where does this red one plug into? I looked on the back of the compressor and hose manifold no plugs or any electrical. Its the high pressure switch i believe correct me if im wrong.
[img alt="
Unless i need to go buy the high pressure switch separately. "]https://cimg0.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1504/20250407_103450_0e877f11a2e3033a606d23d60a6135f94e 50158f.jpg[/img]
I got the 980k6 duralast belt from autozone says effective length is 98.0. It's still too short. Says it fits the f150 4.9 with the a/c. I got the new compressor with the smaller pulley. Some how it's still too short.
I'm also installing it the way the diagram on the truck states.
Never had this problem installing belts in vehicles before
Any other belts you guys recommend?
