1994 F-150 a/c conversion
Old Mar 6, 2025 | 09:04 AM
Jay94f150's Avatar
Jay94f150
Well I think I made a mistake and without knowing the year I pulled an Hvac box out of a 93 F250 with a 5.8.
I've been reading some a/c things changed with the 92-93 and 94-97.
Is the hvac box at least the same with them all? 🤞
Old Mar 6, 2025 | 09:25 AM
Hit Man X's Avatar
Hit Man X
No, evap is slightly different sized as '94+ were 134A trucks. The dryer is also different which also changes the line set and liquid line.
Compressor is the same, so there is that.
Old Mar 6, 2025 | 10:16 AM
My4Fordtrucks's Avatar
My4Fordtrucks
But it will have the wrong oil in it so that’s a negative
Old Mar 6, 2025 | 10:18 AM
Jay94f150's Avatar
Jay94f150
Damn well thanks for the advice. I found a 95 f150 with 5.8 in a different yard I'll snag parts off of.
thank you for the quick reply!
Old Mar 6, 2025 | 10:20 AM
Scndsin's Avatar
Scndsin
Any of you guys have that "sealed/no disconnect- AC install" thread bookmarked?
I can't seem to form a on-site or external search to find it.
Old Mar 6, 2025 | 10:25 AM
Hit Man X's Avatar
Hit Man X
I cannot recall a new comp purchased today that has mineral oil in it unless NOS. The GPD brand (I think) for my '92 4.9 had PAG or whatever. So yes you are correct on that aspect to verify oil.
So, physically the comps are the same until you go back to my '88 with the FS6 then in '89 changed to the newer style.
Went through all the examining of stuff due to running parallel flow condensers on my older rides (pal's '89 too) and have a '97 F250 evap box on shelf.
Old Mar 6, 2025 | 01:04 PM
rla2005's Avatar
rla2005
Not actually a thread, but Steve83 documented how he installed a complete 1995 A/C system in a 1993 Bronco without opening it up to atmosphere: https://www.supermotors.net/registry/21191/71804-2
Old Mar 6, 2025 | 07:19 PM
Scndsin's Avatar
Scndsin
Thanks, not interested in doing, just how it was done.
Old Mar 6, 2025 | 07:26 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by Jay94f150
It's been in the 20s about to go into the 40s this next week and higher.
At these temps , 5w30.
if you change oil twice a year, 10w30 would be my fill right now since it’s warming up
Old Mar 6, 2025 | 07:29 PM
AuroraGirl's Avatar
AuroraGirl
In 1994 the 7.5 and 4.9 compressors changed the pulley size of the ac compressor
Old Mar 30, 2025 | 01:32 AM
Jay94f150's Avatar
Jay94f150
Been installing this a/c components. Ran into two snags so far. A friend had a truck with a 7.5 motor, gave me a compressor of course the pulley is too big. Not sure if you can swap the pulleys with a smaller one.
Also my line to the back of the compressor doesn't have the electrical connection I assume that's for the high side cut out..... hopefully its ok. Obviously have the plug for the compressor itself.
Old Mar 30, 2025 | 04:23 AM
manicmechanic007's Avatar
manicmechanic007
Yes, you can swap the pulleys and field coils
The new Ford compressors come bare with no clutch
You have to buy the pulley, field coil and clutch hub separately
Old Mar 30, 2025 | 08:44 AM
  #28
Hit Man X's Avatar
Hit Man X
What line to the compressor?
High side cut out switch screws onto the back of compressor's line set. Look at an ETM to see if your '93 had this. '96 has it and my '92 does not.
Current new production compressors use same pulley. I would not want a used FS10 unless for mockup only.
Old Mar 30, 2025 | 09:27 PM
  #29
Jay94f150's Avatar
Jay94f150
Ok my problem was I couldn't get the new serpentine belt to go on because the pulley was too big. So if I buy one that says it works with the 4.9, 5.0, 5.8 I should receive the smaller pulley right? But if I buy one that says it works for the 4.9 and 7.5 I'll be back in the same boat with the bigger pulley I would assume?
Old Mar 31, 2025 | 12:18 AM
  #30
AuroraGirl's Avatar
AuroraGirl
Im not sure if the 4.9 and 7.5 had the same pulley before the 94 changeover I mentioned as the 5.8 or 5.0
