Smokey 352
Old Feb 14, 2025 | 02:31 PM
ken$'s Avatar
ken$
4th Gear
Angry Smokey 352
Just bought a 1967 F100 with regulation 352 from Texas. All original (I think) . Runs fine but smokes really bad . 1Qt. of oil in half hour idling.
Compression runs even at 100- 120 on each cylinder but plugs are very oily when I removed them. Because all cylinders are equal and all plugs are oily
I am thinking Valve seals but need direction??? Any other ideas?
Old Feb 14, 2025 | 04:40 PM
davelj's Avatar
davelj
It's just worn out. Valve guides, rings, seals are probably all gone. Leaded gas and the old oil formulas did not promote long engine life.
Valve seals rarely cause smoke at idle unless the guides are also shot. Idle smoke is usually rings. If it was just bad valve seals, it would mainly smoke after you rev it and let off the throttle.
Sorry to be the bearer of bad news.
Old Feb 14, 2025 | 07:51 PM
fe390pc's Avatar
fe390pc
Sounds like the oil rings may be stuck or worn out. There are some possible things to try, either seafood or maybe trans fluid poured through the card as its running. Others may have some things to try, but the bottom line is the engine may need to be refreshed.
Old Feb 15, 2025 | 08:29 AM
ken$'s Avatar
ken$
4th Gear
Smokey 352
I figured that when I got it but for the cost of the seals I might just try it. Thanks, Dave
2ManyCars
Apr 21, 2021 05:47 AM
macgyver55
Oct 7, 2013 09:05 PM
rdweathers
Jan 3, 2013 07:48 PM
dustinleavitt2000
Aug 18, 2003 12:52 PM
mattb
May 14, 2000 05:10 AM
