Fifth wheel, TPMS & Camera
Old Feb 11, 2025 | 04:45 AM
bertscw's Avatar
bertscw
I’ll try to ask this correctly. I just moved from a 2019 F250 with a TPMS and camera on the back of the trailer. my new truck a 2024 F350 has backup assist and a harness came with it for using backup assist on a fifth wheel. Does anybody know how I’m supposed to combine both systems with only one 12 pin plug available? I did plug my original wiring harness from the 2019 into the new truck before I bought it and the camera and TPMS did work. I’m just not sure how to combine the sensor for the back up assist into that system.
Old Feb 11, 2025 | 07:33 AM
FDNYL136's Avatar
FDNYL136
tpms
it is all combined into one harness and uses the same factory connection .The yaw sensor for pro trailer backup is the addition to tpms/camera system. I believe there’s a thread on adding it to your original harness . nichols manufacturing and welding are very knowledgeable on the system and have everything parts wise if you need
https://nicholsmanufacturingandweldingservices.com/
Old Feb 11, 2025 | 07:51 AM
bertscw's Avatar
bertscw
I had forgotten about Nichols... I used their kit to move the bumper plug to to bed on my 2019. Thanks for the lead.
Old Feb 11, 2025 | 08:12 AM
FDNYL136's Avatar
FDNYL136
fifth wheel
I believe I added the pins from my yaw sensor harness into my existing harness connection
Old Feb 11, 2025 | 10:40 AM
Philly35's Avatar
Philly35
The trailer TPMS, camera, and yaw sensor all run off the one 12 pin plug. There is a harness that has a 12 pin plug and a pigtail to go into the yaw sensor on one end, the other end has a pigtail for the camera and a pigtail for the TPMS module. The harness that came with your new truck has a 12 pin end and the other end goes onto the yaw sensor. That harness won’t work with the TPMS/Camera. The harness you have doesn’t have a pigtail for a yaw sensor. You need a new harness.
Old Feb 11, 2025 | 10:41 AM
bpounds's Avatar
bpounds
I believe you need harness P/N PC3Z- 15A416-A. Ford calls it a Base Harness. It will have connectors for Yaw, TPMS, Camera, and it all plugs into the 12 pin connector. I believe this will be used in place of the harness that came with your truck, which I assume only has the Yaw connector.
I'm actually surprised that your older camera works on the new truck. I know the camera changed at some point.
Old Feb 11, 2025 | 12:32 PM
bertscw's Avatar
bertscw
I was hoping not to have to rewire the fifth wheel but it appears I will. Hopefully the old camera will plug into the new harness. It picture quality is not great but it did work.
Old Feb 11, 2025 | 09:28 PM
FDNYL136's Avatar
FDNYL136
fifth wheel
you don’t have to , you can just add the short yaw sensor harness to it .
FordInMT
Mar 1, 2025 04:11 PM
Eman85
Jun 15, 2024 02:10 PM
kry226
Aug 13, 2023 12:26 AM
sohcmike
All Things Towing
May 26, 2022 08:37 PM
Buckeye71
Mar 7, 2021 02:19 PM
