Explorer 3.5 no heat!
2017 police intercepter blows cold air at idle and warms up with accelerating I’ve replaced water pump,thermostat,actuator door and still the same I may have air lock but I’ve done everything I can I need some ideas of what it could be I’m lost
If it has a radiator cap, remove it and start the engine and let it warm up. Squeeze the upper radiator hose tightly and release several times. If the antifreeze level raises and the drops lower than before squeezing the hose, you have air in the system. Keep squeezing and releasing until the level returns to the same level every time. Keep topping off the antifreeze as you go to prevent another air pocket. Replace the radiator cap and see if that fixes your problem.
jessica holbrook
Apr 5, 2004 10:44 PM
stangz
Nov 21, 2002 10:52 AM
myra101
Jan 24, 2002 08:11 AM
