Idle question
Old Feb 9, 2025 | 12:27 PM
Ian1643's Avatar
Ian1643
1st Gear
Idle question
2024 350 6.7 powerstroke
starts at a slow idle then speeds up after a few minutes
If I tap the gas pedal it goes down again then after a while speeds up again to about 800 rpm.
Is this normal? Should I let it idle at the higher rpm?
How long should I warm it up when not towing and when towing?
Thanks in advance.
Ian
Old Feb 9, 2025 | 01:28 PM
Walleye Hunter's Avatar
Walleye Hunter
High idle seems to be normal under the right circumstances but nobody seems to know what the circumstances are. A couple of weeks ago, it was really cold out, below 20 and mine went to high idle. Like you said, when I touched something, it dropped down but then went back up.
Old Feb 9, 2025 | 03:28 PM
powerboatr's Avatar
powerboatr
Yup normal strategy
no real clear parameters in om
Old Feb 9, 2025 | 05:04 PM
IADiver's Avatar
IADiver
Probably has something to do with charging rate on alternator.
Old Feb 9, 2025 | 05:09 PM
Painted Horse's Avatar
Painted Horse
Yes it's normal.
Put your seat belt on, check your mirrors and drive. Extended idling is not good. You are better off to just drive normal to warm up your truck.
Old Feb 10, 2025 | 02:10 AM
Euroman's Avatar
Euroman
I idle long enough to get the oil moving then drive on a light throttle until the water temperature is normal. Extended idling, as stated, is not good. A diesel motor is just too efficient at idle to warm up quickly, unlike a gasser.
Old Feb 10, 2025 | 09:41 AM
powerboatr's Avatar
powerboatr
It would nice
if ford enable seic. Via the cruise button
my freightliner isc powered motorhome
Yiu turn on cruise, set park brake, adjust idle speed via accell decell slide swith on colum
makes it very convenient
Old Feb 10, 2025 | 10:22 AM
JoeUser's Avatar
JoeUser
Originally Posted by robert sloane
It would nice
I'm sure that Ford's legal department probably put the kabosh on that idea. No telling how many knuckleheads would find a way to launch their trucks through garage doors or run over pets and/or children misusing or not following procedures for such a feature (somehow)...
Old Feb 10, 2025 | 10:43 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
My '17 does the same thing. Much more noticable then the previous '17 I had which was very quiet. I've always let my truck run just to get the oil circulating in the engine. Not too long maybe 2 or 3 minutes then hit the road. I still let my engine cool down a bit after running on a hot day just to let the turbo or turbo's cool down. This was drilled in my head when I started driving semi trucks in the early 70's. Company required 3 to 5 minutes starting a cold engine and the same times to cool off.
Old Feb 10, 2025 | 10:06 PM
powerboatr's Avatar
powerboatr
it won't work if drive or reverse is selected and air brake has to be on
I
but yes I can some issues if safety is bypassed
ag-ford-4x4
Nov 3, 2024 03:57 PM
Vincent_Diesel
Oct 11, 2023 08:41 PM
CDNMuddawg
6.7L Power Stroke Diesel
Dec 8, 2020 09:54 PM
LARIAT 85
May 7, 2017 04:17 PM
pullinair
Jul 3, 2007 04:31 AM
