4 link pinion angle
Old Feb 8, 2025 | 06:44 PM
330pbr's Avatar
330pbr
4 link pinion angle
i got a heidts 4 link for my 56 and need help with it ,,, motor is 3degrees down
internet says my rear end should be 4-4.5 up
is this correct before i start welding...... what are you guys setting it at for best results
Old Feb 8, 2025 | 06:57 PM
52 Merc's Avatar
52 Merc
Pinion angle and crank angle need to match (be parallel), with the vehicle and suspension at ride height. Suspension type makes no difference. This is about u-joint operation and drive line vibration. If the engine is pointing 3 degrees down, you want your pinion 3 degrees up. 4.5 is too far out, imo.
Technical - pinion angle ? | The H.A.M.B.
U-joint angles in two planes? - Team Camaro Tech
Pinion & U-Joint Angles
Old Feb 8, 2025 | 07:55 PM
CharlieLed's Avatar
CharlieLed
The beauty of a 4-link is that the pinion angle is fully adjustable after installation by lengthening/shortening the bars. While it is true that the ujoint bearing need at least 1 degree variance the properly lube themselves, I don't think it possible to set up a driveshaft at zero degrees... 1 degree ain't much.
Old Feb 10, 2025 | 04:30 PM
Waygonner's Avatar
Waygonner
https://youtu.be/gmV4qwLfOMY?si=DCxi8TNPatDSMuD_
I followed this logic when I installed my no limit 4 link a few years ago. Can confirm it works great with no premature joint wear or weird vibrations. Great summary!
lowtrkn2k
Sep 9, 2008 11:59 PM
theGman
Apr 10, 2006 07:50 PM
Micginish
27
Jan 24, 2006 01:40 PM
atccracing
Nov 2, 2004 07:39 AM
Idiomaticman
Offroad & 4x4
Feb 20, 2004 12:48 AM
