Sponsored by: Innova
Rear right speaker doesn't work
Old Dec 3, 2003 | 03:32 PM
truckfreak69's Avatar
truckfreak69
Today I heard a cracking sound and then my stereo sounded funny, I've decided that it's the right rear speaker, it has no sound other than a noise similar to when you turn your tv to a station that you don't get. I've also decided that something was wired wrong when my kenwood head unit was installed because when I change the balance to full right side, you can barely hear anything but when you change it to full left you can hear it loud and clear, but when everything is even, it does seem to come out evenly on both sides. Any ideas?
Also when you change it to full right side the woofer doesn't make any noise, but when full left it does, in fact everything left of even (real technical terms i know) it makes noise.
Old Dec 3, 2003 | 05:00 PM
triton_2002's Avatar
triton_2002
Sounds like bad wiring. Who did the install of your HU? If you paid for it, take it back and have it fixed. If not, I guess you're gonna have to pull out the HU and check the wiring. Are you using an amp? An amp can cause balance and fading problems if you only use one output from the HU. Make sure you check the phase of the speaker connections, out of phase speakers can really sound like crap. Hope that helps
Old Dec 3, 2003 | 05:38 PM
Renegadesrun's Avatar
Renegadesrun
Someone wired everything on the left side of the deck. Your right side speaker connections should be unused.
Old Dec 3, 2003 | 05:40 PM
drunkenmonk's Avatar
drunkenmonk
what happens when you use the fader?
Old Dec 3, 2003 | 05:58 PM
Renegadesrun
Was it always this way? If everything worked well before and only now do you have a problem? .....if so then i would check for crossed wires. If the wires are all solid i would buy a new deck if you can live with it being brain damaged.
Waiting for you, answer the above q, to check the fader, and wires on the back of the deck to try to venture anything else. Wish i was there.......
Old Dec 8, 2003 | 10:39 PM
truckfreak69
I forgot to check it without the xm radion on, ie. with a CD or radio on, it turned out one of the solders on the output of my XM radio cracked. Guess I gotta re-solder it.
mzender
2004 - 2008 F150
Jan 24, 2013 04:37 PM
nmventure
15
Jan 19, 2011 11:33 AM
naiku
Jul 6, 2006 07:19 AM
fatfenders
54
Dec 21, 2004 08:01 AM
ncmom2_3
May 9, 2002 12:25 PM
