yes what are the castings on your block, i have a book i can look them up in, on my block on the passenger side there is a casting D3TE, that means it was made in the 70's C means 60's, but there are also othe castinfs by the oil filter adapter to, just find the castings and post back ill take a look in my book.
Hey Thanks Fordman!
I didnt look by the oil filter, but the numbers on the passenger side rear of the block are: D1VE-6015-A2B
If that doesnt do it, I will look for the numbers by the oil filter on friday and post again.
oh nevermind i read your post of you castings wrong your block is a 1971, the rest of the #'s u posted are parts #'s, looks like you have an original engne in your truck, good luck.
Can anyone give me a particular location on the head or block on a 300 6-cylinder to start scraping grease off to look for casting numbers? Manifolds are no good since I had to have them swapped out. Thanks.
