2001 Ranger Airbag Code 27
Anyway, I am getting a Code 27 Airbag code on my 2001 Ranger. I understand from reading this forum that it's a burnt bulb and that the airbags won't deploy in an accident. Now, the dealer wants hundreds of dollars to fix this and frankly, I can't see spending that kind of money on this particular thing. Is there any HARM to NOT getting it fixed (with the exception of the airbags not deploying, of course). I wish we were a little handier and we would do it ourselves.....
Thanks for your time and insight!
Julie
B1890 27 16 Passenger Air Bag Deactivation (PAD) Warning Lamp
Passenger Air Bag Deactivation (PAD) Switch
Removal
WARNING: Always wear safety glasses when repairing an air bag supplemental restraint system (SRS) vehicle and when handling an air bag module. This will reduce the risk of injury in the event of an accidental deployment.
WARNING: To reduce the risk of personal injury, do not use any memory saver devices.
NOTE: The air bag warning lamp illuminates when the RCM fuse is removed and the ignition switch is ON. This is normal operation and does not indicate a supplemental restraint system (SRS) fault.
NOTE: The SRS must be fully operational and free of faults before releasing the vehicle to the customer.
NOTE: A repair is made by installing a new part only. If the new part does not correct the condition, install the original part and perform the diagnostic procedure again.
Depower the system. For additional information, refer to Supplemental Restraint System (SRS) Depowering and Repowering in this section.
Release the clips and remove the utility tray (if equipped).
Remove the instrument panel ash receptacle (04810).
Remove the ash receptacle bracket.
Remove the retaining bolts.
Disconnect the passenger air bag deactivation (PAD) switch electrical connector.
Remove the passenger air bag deactivation (PAD) switch cover.
Remove the passenger air bag deactivation (PAD) switch.
Remove the retaining screws.
Installation:
Install the PAD switch.
Position the PAD switch to the instrument panel finish panel.
Install the screws.
Install the PAD switch cover.
Connect the PAD switch electrical connector.
Position the ash receptacle bracket. Install the screws.
Install the ash receptacle.
Install the utility tray.
Repower the system. For additional information, refer to Supplemental Restraint System (SRS) Depowering and Repowering in this section.
