What's This?
Old Feb 4, 2025 | 07:00 AM
Grey County Hermit's Avatar
Grey County Hermit
What's This?
I pulled out some panels to play around with the front air dams, and this was in my pile of parts. Not sure exactly what it is or where it goes. Does this familiar to anyone? My truck is a 1950 1/2 ton.
Old Feb 4, 2025 | 07:18 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
The often missing splash shield! You are lucky to have one!
Old Feb 4, 2025 | 12:25 PM
52 Merc's Avatar
52 Merc
It attaches to the frame rails under the engine aft of the front crossmember and radiator.
Old Feb 4, 2025 | 12:34 PM
Grey County Hermit
Thanks guys! I had no recollection of having removed that myself, so it was probably one of the many loose parts that came with the truck. It turns out to be a moot point anyhow, as both my LS engine and my Mustang ll suspension sit exactly where that pan should go!
Old Feb 4, 2025 | 07:41 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
often removed, rarely reinstalled but a very important piece. It's one of the key components that help direct air flow through the radiator core
Old Feb 5, 2025 | 03:33 PM
brain75's Avatar
brain75
since a guy has one and has it loose.... could you be troubled to trace it out on paper and go to the local library to have it scanned into a large format pdf (then the rest of us guys who have none could go to the library and have it printed out pdf for home fab/repro)... or sell copies of the tracing yourself...
Old Feb 5, 2025 | 03:54 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
The 48 to 51 pan is being repop’ed by Dennis Carpenter. Below. Won’t fit 52s because the frame motor mounts were modified to work with the new 215 engine. Stu
Old Feb 5, 2025 | 03:57 PM
bmoran4's Avatar
bmoran4
All the repops have the draft tube hole. Notice this original does not.
Also, like you said, 52 is different with the 2C-6775 plate that deeper and shaped differently.
Old Feb 5, 2025 | 06:46 PM
Grey County Hermit
Wow, this splash pan question was a big hit! Brain75, I checked with my better half who determined that our local library (small & rural) doesn't have the ability to do stuff that size. I didn't realize that the big issue was the draft tube hole that is punched into the repops. How come you guys aren't just getting a repop and welding in a round patch to fill the hole? Seems a lot easier than fabbing one from scratch or fixing up a cruddy old one!
Old Feb 5, 2025 | 07:33 PM
52 Merc's Avatar
52 Merc
I believe the hole is an early and late thing. Some have it, some don't. The replacements have the hole because some need it, and if it doesn't, it's no big deal. Looking back through old catalogs, there's several versions of the pan, dependent on different draft tubes which changed over the years. After 52, all other pans were made obsolete and the replacement was the 52 version.
EffieTrucker
Nov 15, 2024 02:06 PM
76F250SuperCab
Feb 15, 2024 05:41 PM
JNeedler
May 21, 2023 06:42 AM
eatyourfish
30
Jan 6, 2023 02:25 PM
