Thoughts on build balancing
Old Feb 3, 2025 | 01:46 PM
foneshiddy's Avatar
foneshiddy
6th Gear
I‘m building a D4 code 351W, stock bore with D5AE-CA heads that are getting rebuilt. I plan on putting an Edelbrock 2181 Performer intake manifold, a 2182 cam, and a 1406 carb. Anybody have any experience with this combination? Any advice? TIA
Old Feb 3, 2025 | 07:48 PM
Conanski's Avatar
Conanski
Why D5 heads? Are you planning on flat top pistons to raise compression?
P.S. I found one source that states those heads have 58cc chambers, is that what you have?
Old Feb 3, 2025 | 07:57 PM
foneshiddy's Avatar
foneshiddy
6th Gear
Yep they‘re the 58cc chamber heads
Old Feb 3, 2025 | 08:45 PM
Conanski's Avatar
Conanski
Are you doing anything to the heads beside the rebuild? Porting?
Overall that is a solid combo, it won't make big HP but should be very torquey.
Old Feb 4, 2025 | 01:17 PM
foneshiddy's Avatar
foneshiddy
6th Gear
No I won’t be porting, the heads anyway. The machine shop won’t since they’re cast and said they’d take forever. I’m gonna run stock springs, but I don’t know what pushrod length to go with, the motor didn’t come with any. I was thinking about running Comp Cam kit RP-1436-16, and it includes the High Energy 8.152” length 5/16” diameter pushrods. Do I need to measure or would these be sufficient?
Old Feb 4, 2025 | 05:29 PM
Conanski's Avatar
Conanski
You should measure, a slight difference in cam base circle,, which isn't unusual, will require custom length puhrods.
gonetruckin
Jan 20, 2004 09:23 AM
bigblocksix
Dec 3, 2003 03:34 PM
mdh627
Jul 16, 2003 03:44 PM
wille3r
Oct 11, 2002 10:53 PM
