Windshield wipers skipping on windshield
Old Jan 31, 2025 | 08:59 PM
FuzzyBeanBag's Avatar
FuzzyBeanBag
Hey folks - hope this is simple enough: my windshield wipers (both) skip on the upwards stroke - new or old wipers, doesn't matter. I am guessing it has to do with a weakened spring in the arm? Is there a method to fix or will I need to hunt for new wiper arms?
Thanks!
Old Jan 31, 2025 | 09:58 PM
tbear853's Avatar
tbear853
Post #11 in this thread was my fix. I probably touch on it in other post afterwards.
New arms, new springs, J hooks, 16" blades, more overlap at center.
Tbear's 77 F150 thread - Ford Truck Enthusiasts Forums
Old Feb 1, 2025 | 03:08 PM
FuzzyBeanBag
Thanks - read your post and while that's a heck of an upgrade, I prefer the original look (especially the shiny stainless steel finish) and don't really have the time (nor really the tools) to do surgery. Can I get away with replacing the spring in the arm (and if so - what spring would I need)? Or source an entirely new (aftermarket) arm(s)?
Old Feb 1, 2025 | 05:02 PM
tbear853's Avatar
tbear853
I don't know that you can readily find the right length springs but they might not be needed. You can still get refill blades, old rubber gets hard, You can get new arms too, I found them on the net like for my '77, but not at the gas station like used to could. Googled "1977 F-150 wipers".
Old Feb 1, 2025 | 06:40 PM
FuzzyBeanBag
Oh I know about the wipers - I do have new ones but they still skip, I think it's cuz of the spring loosing its tensile strength and not keeping things tight anymore
Old Feb 1, 2025 | 09:58 PM
SlikWillie's Avatar
SlikWillie
More than likely there is a build up of dirt and crud on the windshield causing the wiper to grip-slide-grip-slide and so on. Scrub the windshield with a good degreaser like Purple Power and then clean it really well with Rainex. Use the new wipers and give it a go with water on the glass. Let us know how that did.
Old Feb 1, 2025 | 10:04 PM
FuzzyBeanBag
I'd normally agree with this buttttt it's a brand new windshield lol. I had the truck professionally painted a couple months ago and when the windshield was being reinstalled with new seals, it cracked. So a brand new windshield was installed in it's place and it's smoother than a baby's bottom.
Old Feb 2, 2025 | 11:39 AM
Old Guy F-250's Avatar
Old Guy F-250
Agree with Slick on this one. New or not, Just because it is new doesn't mean there is not crud on it..
Usuall some kinda crud, or, overspray.
Good cleaning usually works.
Old Feb 2, 2025 | 11:48 AM
tbear853's Avatar
tbear853
Occasionally, I'll take a bottle of Windex and a glass scraper blade, wet the windshield in spots as a lubricant, and lightly run the scraper through the wet Windex. Follow up with paper towel and Windex. Doesn't take much pressure, just keep the blade like 30-40 degrees to glass. Amazing the number clicks heard as the scraper removes deposits from "clean" windshields.
Another favorite like for water spots, is a powderery product "Spot X", it's ground up sea shells. Dampen a paper towel, put a little powdered sea shells on it, wipe good, then clean with the Windex.
Old Feb 2, 2025 | 04:42 PM
tbruz's Avatar
tbruz
Been looking for the real Spot-X product for a while now.
None available at Walmart, Ebay or Amazon.
Anyone know where to find it?
Thanks in advance
Tbruz
Old Feb 2, 2025 | 08:12 PM
tbear853's Avatar
tbear853
Thanks in advance
Tbruz
Only place I saw it was where I bought minet, was at an ACE Hardware. Wonder if Lowe's or Home Depot had it but come to think on it, that was likely 10 years ago, maybe longer I bought mine, but it keeps. There are others now.
Old Feb 2, 2025 | 08:18 PM
FuzzyBeanBag
Huh - OK fair enough. I'll give it a shot! What kind of a scraper do you use? Plastic blade or...?
Old Feb 2, 2025 | 08:32 PM
tbear853's Avatar
tbear853
A plastic handled razor blade holding scroper, just let it glide. Use the Windex as a lubricant. Glass is harder than steel, but you can practice first. We used them to remove inspection or county stickers too.
This will work:
Amazon.com: Bates- Razor Blade Scraper, Pink, Locking Razor Scraper Set with 10 Extra Stainless Steel Blades, Window Scraper, Scraper Tool, Glass Scraper, Scraper Blades, Paint Scraper Blade Scraper for Cleaning : Tools & Home Improvement Amazon.com: Bates- Razor Blade Scraper, Pink, Locking Razor Scraper Set with 10 Extra Stainless Steel Blades, Window Scraper, Scraper Tool, Glass Scraper, Scraper Blades, Paint Scraper Blade Scraper for Cleaning : Tools & Home Improvement
Old Feb 3, 2025 | 12:30 AM
FuzzyBeanBag
This will work:Amazon.com: Bates- Razor Blade Scraper, Pink, Locking Razor Scraper Set with 10 Extra Stainless Steel Blades, Window Scraper, Scraper Tool, Glass Scraper, Scraper Blades, Paint Scraper Blade Scraper for Cleaning : Tools & Home Improvement
Thanks!
Fordication
May 1, 2024 10:18 PM
is300wrx
2004 - 2008 F150
Feb 5, 2006 11:29 AM
Mezmo
2004 - 2008 F150
Jun 28, 2005 08:14 PM
eigenvector
1983 - 2012 Ranger & B-Series
Feb 26, 2004 04:19 AM
66worktruck
Jan 22, 2001 12:45 PM
