Windshield Wipers
Old Apr 29, 2024 | 07:39 PM
Fordication's Avatar
Fordication
Windshield Wipers
93 Ford F150 Reg Cab 4x4 flareside. Ok new problems. I put new wiper blades on the windshield. I am having a problem. The work great at sitting and low speed. The driver side starts lifting at about 40MPH and does not clean the windshield. Is there and adjustment to make the spring stronger?
Old Apr 29, 2024 | 07:50 PM
spurredon's Avatar
spurredon
Put the old ones back on and see if they still act the same.
Old Apr 30, 2024 | 05:30 AM
AuroraGirl's Avatar
AuroraGirl
show us?
The arm may be bent. new arms are still sold from ford, with J hooks too
Old Apr 30, 2024 | 10:03 PM
Fordication
Yes. Every time I tried a different wiper blade it lifts off of the glass. Some do not even have to have acceleration.
Old May 1, 2024 | 01:58 AM
AuroraGirl's Avatar
AuroraGirl
is the little metal clip that holds the windshield wiper arm off the glass partially engaged at the pivot of tjhe wiper arm?
Old May 1, 2024 | 07:15 PM
Fordication
You were right. There was not enough arch in the wiper arm so I bent it a little today and then it rained all the way home from work. The wipers worked great. The drivers side was the one that was not working great so I ben it a little and did the same to the passengers side. Made a huge difference and now no problems. Of course, I already ordered a new set of arms from LMC so now I have to see if I can sell them or return them.
Old May 1, 2024 | 08:23 PM
Conanski's Avatar
Conanski
This problem is a result of the windshield rake.. it's too steep and creates air turbulance at higher speed. They used to sell little wings to clip on the wiper arm which did help, and then some wipers encorporated a wing shape in the blade to accomplish the same thing. Bottom line is do whatever you need to do to make them work, new wiper arms may or may not make any difference.
Old May 1, 2024 | 10:18 PM
AuroraGirl's Avatar
AuroraGirl
arms mistakenly yanked back to flip them up like a lot of cars, like gm trucks at the same time, most likely ruined this. Partially stuck clips that have to be done to remove the arm from the stubs as well ''''c
ArToolMan
2021+ F150
Nov 6, 2022 04:20 PM
mwillmont
Oct 3, 2017 12:04 PM
Mezmo
2004 - 2008 F150
Jun 28, 2005 08:14 PM
dawid311
Aerostar
Mar 26, 2004 10:34 PM
