Hey everyone. I normally hang out in the 1956 forum, but I'm having issues with 2013 F150 3.5 Ecoboost with 151,000 miles. Was driving the other day and stopped and shut it off. Went to restart and it sounds like the starter is just spinning not engaging the flexplate. It never made any abnormal noises while driving. Checked fuse 27 and that is good. Plugged the scan tool in and got a whole list of codes. Starting with P0016 cam/crank position sensor bank 1, P0017 cam/crank position sensor bank 1, P0019 cam/crank position sensor bank 2, P0022 timing over retarded bank 2, P0299 turbo underboost, P0365 cam position sensor bank 1 CKT malfunction, P0369 cam position sensor bank 1 intermittent, P0394 cam position sensor bank 2 intermittent. Could this be as simple as cam position sensor, or as involved as a timing chain and phasers?
I’m not sure if this will work, but here is a video
That sounds like an engine with no compression, broken fly wheel maybe. Need to get eyes on to be sure. Have a helper spin it over while you watch the drive belt, does it move?
