I am currently looking at a 2002 F-350SD 4x4 SRW and on the paperwork it says it has a "camper package". I've looked at spec sheets, etc. but haven't seen any details. Just what does the camper package include? Thanks for any info!
[updated:LAST EDITED ON 07-Jan-03 AT 00:10 AM (EST)]I will be corected if I am wrong but I beleive it is front and rear sway bar and the certification to haul a camper. Not sure what else I forgot
I also think they use the heavier front springs. Not sure if they are the same as in the snow plow package, but I am sure they are upgraded anyway. The shocks may also be a little heavier also. Also, I think they throw in a single leaf "helper" spring in the rear as well.
i believe the camper package has to do with a slide in camper certification and a rear sway bar. As far as I know, all of the superduty truck come standard with a tow package.
[updated:LAST EDITED ON 07-Jan-03 AT 10:47 AM (EST)]The camper package gives you the maximum springs (f&r - if your other mods don't already have you at max) adds the rear sway bar and I believe the others are correct about the rear helper spring.
Gary M.
White 2002 F250 SD, SC, SB, 4x4, 6.8L v10, 3.73LS, 4spd Auto, Reverse Aid Sensor, Class IV Hitch, Offroad Package, Manual Hubs, 40/20/40 Bench Seat, Towing Package, Camper Package, Lariat, Putco Locker Side Rails, Mud Flaps, K&N Filter, Vent Visors, Aluminum in-bed Tool Box (sits in the bed, dosn't hang over the bed rails), Vent Visors, CB radio w/102" SS Whip Antenna, Autolocks programmed off, Seatbelt Minder programmed off, Key in ignition sensor wire dosconnected...
White 2002 Ranger 4x2 3.0L V6 XLT 2 door supercab with the power group, auto, chrome wheels, mud flaps, body side molding, vent visors, Leonard cab high fiberglass camper shell, and the 60/40 bench seat as my daily driver
CAMPER PACKAGE (532)
• Heavy service front springs (200 lb. Upgrade above the spring computer selected as a consequence of options chosen. Not included if maximum springs have been computer selected as standard equipment)
• Rear stabilizer bar
• Auxiliary rear springs
• Slide-in camper certification
