Engine Block heater working
Old Jan 26, 2025 | 12:00 PM
erich505's Avatar
erich505
Trailering
How can you tell if the engine block heater is working? My 24XLT came with one even though I live in New Orleans area. Well, if you watched the news lately, you saw what we were hit with. So, while stuck at home, I decided to experiment. I plugged in my heater expecting the snow to melt off the hood of the truck after a few hours. Nothing. I unplugged and started the truck to let it warm up. It was mid 20s but the truck started as easy as it does in warm weather. I noted the water temp gauge read 80-ish. I assumed that this meant the block heater did its job. But, I'm not sure. Can someone with more experience with the heater give a couple things to look for in case I ever need to use the heater again???? Thanks.
Old Jan 26, 2025 | 01:35 PM
Leardriver's Avatar
Leardriver
That sounds fairly scientific. I look at the coolant temp at starting versus ambient temp.
Old Jan 26, 2025 | 01:52 PM
powerboatr's Avatar
powerboatr
if your water temps were above outside air temps, when you 1st started .... its working
it will cycle to maintain
Old Jan 26, 2025 | 01:58 PM
Tib's Avatar
Tib
I'm pretty sure my coolant always says 86 when starting like it's the lowest it reports, but with the block heater I get around 89-93. I could be wrong, I'll check tomorrow morning as I am running trickle chargers with the cord so will not have it plugged in.
I have it on a metered plug and it runs 100% without stopping at approx 900w the whole 3 hours I have the plug active.
It does start instantly, no short delay on the glow plugs and the cab is warming up within half a mile. Supplemental helps there though.
Old Jan 26, 2025 | 02:18 PM
Rwhjr's Avatar
Rwhjr
My truck reads well below 80° coolant temp when starting on cold days.
If he’s coming out in 20° weather and his coolant temp is 90° then I’d say it’s working. But then again, maybe we can get some more numbers from people who use the engine block heater and see their numbers too.
Old Jan 26, 2025 | 03:58 PM
kry226's Avatar
kry226
I've had the block heaters on my previous 6.2 and the current 7.3 gassers, but I haven't used them much. However, I used the block heater on my 2004 5.9 Cummins extensively. For starters, a few seconds after plug-in, I could always hear a faint gurgle in the block as the antifreeze began to warm up. Almost sounds like a Keurig warming up. Similar principle. Second, while I never saw it melt snow or ice off the hood, it did a great job on the windshield. Many mornings I walked out to see a nice half-moon of clear windshield extending from the cowl.
Again, not saying this behavior extends to your 6.7, nor am I trying to compare apples and oranges, but a block heater is a block heater is a block heater too. It's simply heating antifreeze within the block.
Old Jan 26, 2025 | 04:02 PM
Tib's Avatar
Tib
Yeah, I remember it being low too, but Im getting a bad case of C R S and have been using that thing for a few weeks now. (CRS is can't remember stuff). Thats why I was going to just look in the morning and see if its CRS or not.
Old Jan 26, 2025 | 04:07 PM
Tib's Avatar
Tib
Originally Posted by kry226
I've had the block heaters on my previous 6.2 and the current 7.3 gassers, but I haven't used them much. However, I used the block heater on my 2004 5.9 Cummins extensively. For starters, a few seconds after plug-in, I could always heart a faint gurgle in the block as the antifreeze began to warm up. Almost sounds like a Keurig warming up. Similar principle. Second, while I never saw it melt snow or ice off the hood, it did a great job on the windshield. Many mornings I walked out to see a nice half-moon of clear windshield extending from the cowl.
Yep,I've heard that sound as well, very faint. it's just an element like a water heater but shorter and lower voltage. On some of our large commercial 100+ gallon heaters when the thermostat clicks you can hear gurgling almost instantly same sound. BTW, people turn new water heaters on all the time without purging the air, and the top element will melt and fail in about 60 seconds. I "assume" they designed the placement so after coolant system work, if some air didn't get purged out it wouldn't sit there on a day where someone actually needs to use the block heater. It's at the bottom of the block so probably not an issue, just something to think about.
Old Jan 26, 2025 | 06:10 PM
Strider250's Avatar
Strider250
No, it does not cycle if it is plugged in it is on and it stays on until it is unplugged, which is why most users of the block heater put it on a timer.
EDIT: If you really want to check the block heater has a resistance between 12.5 and 17 ohms.
Last edited by Strider250; Jan 26, 2025 at 06:17 PM. Reason: Added resistance values.
Old Jan 26, 2025 | 06:44 PM
HFM's Avatar
HFM
Trailering
Active Streak: 30 Days
My truck took an update a couple of days ago and now ECT never reads below 86F. Talked to a buddy today and his truck is now not reading below 86F after an update. It’s been single digits ambient temps. Trans and oil temps are reading correctly.
Hmm wonder what’s up with that.
Old Jan 27, 2025 | 12:44 AM
willynilly's Avatar
willynilly
easiest quickest way is just test with multimeter. sounds like the dash dispay is useless as it doesnt read below 80 ? if it read water temp with no limitations then of course this would also tell if the block heater was working
Old Jan 27, 2025 | 06:13 AM
1olddogtwo's Avatar
1olddogtwo
I haven't used any of mine in years, but I do remember at night seeing a spark and hearing it when plugging the extension cord in to the truck, assume the cord is plugged into a power source of course.
I don't think much has changed considering it's the same type of coolant heater that have been used for decades.
Old Jan 27, 2025 | 06:18 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Interesting to note that Ford changed the readout on coolant temp to not read below 86°. My Ram reads at least as low as 40...I haven't been in it and started it after sitting overnight, since it has remote start. It's a programming change, I would presume you could edit that with Forscan.
To the OP, at mid-20's, if it isn't waiting to start with the block heater plugged in, then the block heater is definitely working. My FIL's '24 waits to start at basically anything under about 35°
Old Jan 27, 2025 | 06:19 AM
Galllagha's Avatar
Galllagha
Banned
The engine block heater is a wonderful feature, especially during cold snaps like the one you experienced in New Orleans. To determine if the engine block heater is working, look for these indicators:
1. Warm engine: As you've already observed, a working block heater will warm up the engine, making it easier to start in cold temperatures. A temperature reading of 80-ish on the water temp gauge is a good sign.
Old Jan 27, 2025 | 06:20 AM
Galllagha's Avatar
Galllagha
Banned
2. Cord warmth: When the block heater is functioning, the cord and plug might feel warm to the touch after a few hours of being plugged in.
3. Reduced cranking time: A block heater will help reduce the cranking time required to start the engine. If the engine starts quickly and easily, even in cold temperatures, it's likely the block heater is doing its job.
4. Coolant temperature: Use a thermometer or a scan tool to check the coolant temperature. If the block heater is working, the coolant temperature should be warmer than the ambient temperature after a few hours of being plugged in.
