Transmission Identification Help
Old Jan 24, 2025 | 09:57 PM
brantoday2's Avatar
brantoday2
1st Gear
I am currently looking to buy this 1986 F150 with a 5.0 and can't seem to find any info on what transmission this may be. The closest I've been able to find is the Tremec T170FT RTS 4 speed with overdrive (link below) but it shows a 4 where this one has the "O". I appreciate any help, I'm new to the classic truck community, if I am able to buy this one it'd be my first.
https://www.fordgarage.com/pages/TremecT170FT.htm
Old Jan 24, 2025 | 10:52 PM
85e150's Avatar
85e150
There were several variations, and your link seems to be correct iirc, regarding the RTS variant.
These were based on the '60s performance 4 speed with some internal fiddling to make the old 3rd gear into OD.
I'll try to find you some more links to them tomorrow.
They are not the strongest transmission, and the gear spread from 2nd to 3rd can be miserable depending on your axle and tire combo.
But, it's lasted this long and will probably continue to work just fine.
Old Jan 25, 2025 | 08:23 AM
Franklin2's Avatar
Franklin2
In all normal 4 speeds, 4th gear is straight through 1 to 1. In this 4 speed overdrive that you have, they reversed the linkage so the labeled 3rd gear is the old 4th and is 1 to 1. The labeled 4th gear is the old 3rd and they made it a overdrive gear instead.
Old Jan 25, 2025 | 08:53 AM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
There should be a sticker on the left door frame post up a picture of it and we can decode it for more information like axle ratio(s), color inside and out.
Dave ----
Matt1966
22
May 1, 2026 10:08 PM
GaBilgerat
May 21, 2023 07:20 AM
fireball 440
1997 - 2003 F150
Jul 10, 2022 02:18 PM
Bearjackson
Aug 29, 2018 11:33 AM
TheWarWagon'75
May 25, 2009 08:24 AM
