Do I have HD cooling?
Old Dec 2, 2003 | 10:35 PM
gregm's Avatar
gregm
I keep hearing about STD, HD, and extra HD cooling in our trucks, but my questionis... whats it all mean. I have a '79 with 351M, thermostatic fan, and 2 row radiator with shroud, and AC. What level of cooling do I have, and what can I do to increase it. I live in NC and the heat and humidity can cook everything, even an engine. THANKS for your help out there.
Old Dec 3, 2003 | 07:17 PM
lloyd33's Avatar
lloyd33
The heavy duty and extra heavy duty just means 3 to 4 core radiators (instead of the standard 2) with larger surface area (length x width) as well, also slightly deeper fan shrouds (like about 3/4") which put the fan more in the path of the hot air. If your truck isn't overheating, then you don't need to do anything to it. If it ain't broke, don't fix it. That extra heavy duty stuff is for people who tow big trailers through Texas in the summer with the air running and the windows down.
Lloyd
Old Dec 3, 2003 | 11:02 PM
f100guy's Avatar
f100guy
i have an 82 supercab f150 with a 302 and a c6. it has a 3 row in it with 2 seperate tranny coolers, one inside the radiator and one in front of the radiator.
Old Dec 5, 2003 | 04:57 PM
gregm's Avatar
gregm
Thanks lloyd33..My truck does overheat in the summer,or gets very hot. I will go up to a 3 or 4 row radiator before the heat gets here.I hope that will help me.Thanks!!
Old Dec 5, 2003 | 06:15 PM
f100guy's Avatar
f100guy
what thermostat are you using i heard bad things about the 195. i live in texas and it is hot here
Old Dec 6, 2003 | 10:40 PM
gregm's Avatar
gregm
f100guy... I am using the 195 one.
Old Dec 7, 2003 | 12:21 PM
f100guy's Avatar
f100guy
try one like a 180 i am not to good with thermostats because i don't mess with them but i have heard bad things about the 195 in hot summer places
Old Dec 9, 2003 | 11:31 AM
MrBSS's Avatar
MrBSS
Here's the thing to keep in mind: If your truck's overheating and your 195 thermostat is working properly, then you have more problems because its already fully open. A lower temperature thermostat would open sooner but that would only slightly delay the eventual overheat. At 225 degrees, everything will be the same whether the thermostat has opened at 165 or 195.
FordTE
Jan 20, 2013 07:55 PM
peter.jones
May 7, 2009 09:30 AM
presrch
Aug 31, 2004 05:09 PM
andrew h
North Carolina Chapter
13
Dec 23, 2003 07:17 AM
bradcdavis00
Jul 12, 2003 11:39 AM
