Sponsored by: Kumho
How to remove leaf spring bushings?
Old Dec 2, 2003 | 09:35 PM
John Barleycorn's Avatar
John Barleycorn
Well, I guess the subject line says it all.
No torch in my garage (yet). Any tips, tricks or advice?
Thanks!
Old Dec 3, 2003 | 10:24 AM
85351ho's Avatar
85351ho
drill the rubber out, use a BFH and a cold chisel/punches
torches r so nice
Old Dec 3, 2003 | 10:27 AM
cgl's Avatar
cgl
Go to the hardware store and get a propane torch (MAP gas works real good). It'll be worth it! Just don't breathe the fumes... YUK!
Old Dec 3, 2003 | 08:02 PM
02superstroker's Avatar
02superstroker
I had this problem in the shackles of my old bronco. If you have a 3-pound sledge you can use a socket to knock it out. Put a large socket on the bottom(big enough for the bushing to fit in) and on the top use a socket that is the same size as the metal sleeve in the bushing. Whack away at it. A few hard hits should bust it free.
Watch those fingers though
Old Dec 3, 2003 | 11:34 PM
Rambomber's Avatar
Rambomber
To do this job correctly you need a press and either sockets or shelby tubing the same size as your bushing, and a buddy to hold the other end of your spring as you press the bushing out. Use dish soap as a lube when going back together -- grease will ruin the rubber over time. Done it this way many times and works every time!
Old Dec 4, 2003 | 10:34 AM
85351ho's Avatar
85351ho
ive never had it that easy.....they are always much more stubborn
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
