Dual Battery issue
Old Jan 21, 2025 | 07:57 AM
vettman's Avatar
vettman
Dual Battery issue
I know there are several dual battery threads on the forum, but I don't believe my issue has been covered completly. I have a 1976 F350 SC Camper Special, 460/C6 with factory dual battery option. I just installed a new passenger side battery. The driver side battery is old and weak. My question: will the new battery discharge to the weaker driver side battery? Will a trickle charger connected to the new battery pass current to the weak battery? Are they only connected for charging when the engine is running?
Thanks for any/all replies
Old Jan 21, 2025 | 10:16 AM
tbear853's Avatar
tbear853
I do recall that they should be closely matched. It might be that mismatching causes issues with charge rate to the better battery ... ... like maybe a thirsty poor aux battery craving current will elevate the charge rate to the better battery, maybe overcharging it.
There is a relay to disconnect/connect the aux battery that is controlled through the ignition switch.
Old Jan 21, 2025 | 10:21 AM
79F150400M's Avatar
79F150400M
There is a solenoid on the driver's side that should be able to isolate the batteries. If it's wired in and working, you should be fine. The batteries won't cross feed thus one draining the other.
Old Jan 22, 2025 | 08:00 AM
vettman's Avatar
vettman
Dual battery
Since the driver side solenoid isolates the two batteries, a trickle charger connected to the passenger side battery will not charge the driver side battery--is that correct? Likewise, with the engine running, will the altenator not overcharge the new passenger side battery as it provides current to the weak driver side battery?
Thanks to you pros that have replied.
Old Jan 22, 2025 | 09:42 AM
79F150400M's Avatar
79F150400M
A trickle charger would be fine and the trucks voltage regulator keeps the voltage to both batteries in check while it's running. This is assuming that everything is working the way it should.
Old Jan 22, 2025 | 01:51 PM
mwallace70's Avatar
mwallace70
Trailering
You can also consider a trickle charger made for two batteries (has two outputs, one for each battery). This is what I have used in the past on large trucks with dual batteries.
bellaireroad
2023+ Super Duty
Dec 29, 2024 07:20 AM
jimzpsd
Oct 14, 2023 07:15 PM
HKusp
Dec 30, 2022 11:45 AM
WeRetired
Nov 11, 2022 06:49 PM
budawe
Oct 7, 2019 09:42 AM
