NEED HELP
Old Jan 21, 2025 | 06:38 AM
10foot's Avatar
10foot
1st Gear
NEED HELP
Hey guys so I have a 94 f150 5.0 2-wd love the truck I saved it from the scrap yard when a dummy thought he had killed it but turned out to need a radiator and a new oil pan seal and here we are 5 years later anyway when it's below 32 and the colder it is the worse this problem gets when I go to start it in the morning it will start but then immediately bogs out if I don't hit the gas and when it's real cold the first few times even hitting the gas it'll bog right out now yesterday it seemed to freeze up on me while I was driving which has never happened now it was 10 degrees out yesterday and I was doing about 50 when it died out on me any ideas what could be causing this?! It doesn't get tht cold normally where I live but obviously once in a while it can get there so any help would be much appreciated
Old Jan 21, 2025 | 07:56 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Holy run on sentence! That was hard to read.
Have you checked for Key On Engine Off Fault (KOEO) fault codes? It could be the coolant temperature sensor is reading colder than what it actually is and over fueling the engine. Having said that do not start replacing parts without testing checking for codes and testing any parts first.
Old Jan 21, 2025 | 09:36 AM
eakermeld's Avatar
eakermeld
Kinda sounds like it has water in the fuel filter and it's freezing up and cutting off the fuel flow.
Old Jan 22, 2025 | 05:41 AM
manicmechanic007's Avatar
manicmechanic007
True story, check the fuel pressure check the codes
Maybe check a few basics, like the condition of the cap and rotor and the spark plugs
Tuned up last when?
Take a sample of the gas
Old Jan 23, 2025 | 09:48 PM
TobyB's Avatar
TobyB
For the starting, I'd start with codes,
and then make sure the engine temperature sender's working.
And +1 for fuel pressure, and flow as well (which you can check by checking pressure at speed)
t
fredbuilt
General Automotive Discussion
24
Feb 1, 2007 07:43 AM
buckeyebronco
1978 - 1996 Big Bronco
Jan 29, 2004 02:48 PM
