Help understanding GCWR
Old Jan 19, 2025 | 05:26 PM
SteveHood's Avatar
SteveHood
4th Gear
I am buying a new F250 6.7 Diesel. I am confused on the towing limit for a 3.31 Axle Ratio. Why are there two GCWR listings?
Old Jan 19, 2025 | 05:54 PM
SARDiverDan's Avatar
SARDiverDan
At the bottom of the chart, what does the #2 represent on the legend. Next to the 30k is a small #2. I suppose that would tell you why one option is 23.5 while the other is 30. Most likely, high capacity axle upgrade.
Old Jan 19, 2025 | 05:58 PM
SteveHood's Avatar
SteveHood
4th Gear
Requires F-250 High-Capacity Axle Upgrade Package (535).
So, does this mean if you plan to tow above 15,900# (23,500 GCWR), then you can go up to 22,000 # if you upgrade to the High-Capacity Axle package? Looking at the Crew Cab 6-3/4.
Old Jan 19, 2025 | 06:19 PM
HRTKD's Avatar
HRTKD
If you're planning to tow long distances, the crew cab long bed gets the 48 gallon tank. Very handy for me when I'm driving through Wyoming and Montana.
Don't look at just GCWR. Consider the payload and how much your trailer's pin weight will be. In general, you'll run out of payload before you run out of GCWR.
Old Jan 19, 2025 | 06:52 PM
SteveHood's Avatar
SteveHood
4th Gear
So, if I am understanding...if the F250's payload is 4000# and the pin weight of my 5th wheel is 3000#, I am safe, even if the 5th wheel GVW is above the 15,900 # ? (assuming no upgraded axle package on a 3.31 ratio)
Old Jan 19, 2025 | 08:03 PM
HRTKD's Avatar
HRTKD
No, not at all. I'm just saying that for many trucks, the payload runs out long before the GCWR does. You may have a pin weight of 3000 lbs, but you haven't taken into account all the stuff you put in the cab, weight of the hitch, etc.
The newer trucks that have higher GVWR can sometimes throw that rule out, but it's still a good rule to keep an eye on.
Old Jan 19, 2025 | 08:41 PM
SteveHood's Avatar
SteveHood
4th Gear
Ok, thanks. Will consider. But, back to my original question....
Old Jan 19, 2025 | 08:48 PM
HRTKD's Avatar
HRTKD
The question in post #1? I thought that was already answered.
Old Jan 19, 2025 | 11:46 PM
ttavasc's Avatar
ttavasc
It was - it's due to the high capacity axle package as the OP posted in # 3. Of course you'll never get close to the 22k due to the low payload on the F-250 diesel.
OP - you won't find an F-250 diesel with 4000 payload, and likely not 3000. Step up to an F-350 in order to get the kind of payload needed for what you are considering.
Old Jan 20, 2025 | 12:21 AM
HRTKD's Avatar
HRTKD
Oh, the screenshot in the first post of the thread is from the Conventional section for the F-250. You need to look at the next page which covers 5th Wheel.
Old Jan 23, 2025 | 04:14 AM
4by4ord's Avatar
4by4ord
The F250 diesel with the high capacity axle is exactly the same truck as the F350 diesel other than badging and door stickers. The F350 has much more payload rating. It has a GVWR of 12400 I believe where as the F250 has a gvwr of something like 11000 lbs. The F250 (especially the diesel) doesn’t have enough payload to haul much of a fifth wheel if you want to stay below the manufacturer’s gvwr. There is little difference in price between a high capacity f250 and an f350 ….. just get the f350.
I think the difference in price between a F250 with the high capacity rear axle and a similar equipped F350 is $170.
Old Jan 23, 2025 | 04:23 AM
4by4ord's Avatar
4by4ord
When you look at that towing guide and see that the F250 can haul a 20000 lb fiver ( or whatever it is that the guide says) it is assuming nothing else in the bed, no kids in the back seat, and a trailer pin weight of 15%. Then you go buy your 15000 lb trailer, get it loaded up and find it has a pin weight of 22%…… you could easily end up with a 3300 lb pin weight plus the 200 lb hitch in the bed of your truck.
Old Jan 23, 2025 | 07:04 PM
tfalk's Avatar
tfalk
Payload will definately be a problem on a 250 diesel. I have almost the same truck but it's a 24 F350 XLT CCSB with a 12,000 GVWR. Payload is listed as 4234. If the F250 has an 11,000 GVWR, the payload on a similar truck to mine would only have a payload of 3234. Put 3000 pounds of tongue weight on the truck and your remaining payload, if you want to follow the payload police, is only 234 pounds for driver, passenger and any other gear in the truck or added to the truck as options, modifications, etc... If you are going to tow a goose or 5th wheel, you really want the 350 unless you don't care about the payload police. And honestly, IANAL and I have no idea what the legal implications would be if you had an accident and they somehow figured out you were over the payload for the truck....
Old Jan 26, 2025 | 06:34 AM
Bugzilla46310's Avatar
Bugzilla46310
tripleframe
Large Truck
Dec 21, 2025 01:29 PM
I'mAllIn
2023+ Super Duty
Sep 18, 2025 11:32 AM
ikylehale
All Things Towing
Apr 2, 2023 09:33 AM
jaygee15
2015 - 2020 F150
Jan 6, 2018 10:14 PM
Davidvc1964
6.4L Power Stroke Diesel
May 22, 2013 10:20 AM
