Dpfe trouble shoot
Old Jan 18, 2025 | 10:32 AM
Boarnold's Avatar
Boarnold
Trailering
Dpfe trouble shoot
I have an 87 f150. I'm trying to troubleshoot the EGR system. The dpfe sensors that I am seeing have two vacuum lines going to it. The thing that I think is mine only has one going to it. Is this the dpfe sensor? How would I check to see if it's good? Thanks.
Old Jan 18, 2025 | 10:37 AM
GoinBoarding's Avatar
GoinBoarding
No dpfe on an '87. You've just got an EGR valve position sensor.
Old Jan 18, 2025 | 10:53 AM
Soup bean's Avatar
Soup bean
What engine is in your truck?
Old Jan 18, 2025 | 11:04 AM
Soup bean's Avatar
Soup bean
https://www.fullsizebronco.com/threa...cement.218407/
If I remember right, the control solenoid (EVR solenoid) should show 20 to 70 ohms of resistance, after unplugging the harness connector, and reading across the solenoid itself.
Old Jan 18, 2025 | 11:12 AM
Soup bean's Avatar
Soup bean
How are you checking for engine codes?
You can hook up a test light to the positive battery terminal, and it will flash them out. Make sure the truck is up to operating temperature first.
Old Jan 18, 2025 | 11:50 AM
Boarnold's Avatar
Boarnold
Trailering
It has a 5.0
I don't know how to get the codes. I decided to look into it because my truck gets horrible gas mileage. I hooked a vacuum pump up to the EGR valve and it broke loose and started to function and the engine stumbled. It turns out I need to replace a bunch of cracked vacuum lines before I can continue seeing if the EGR system works.
Old Jan 18, 2025 | 12:24 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Boarnold
It has a 5.0
Look at the post right above yours. Post #5
Old Jan 18, 2025 | 12:27 PM
Soup bean's Avatar
Soup bean
Warm up the truck first, then follow this link. https://web.archive.org/web/20120918...tion.com/?p=13
Old Jan 18, 2025 | 12:33 PM
Soup bean's Avatar
Soup bean
Chiver
1983 - 2012 Ranger & B-Series
37
Jun 24, 2014 10:34 AM
Volvo92906
36
Jul 28, 2009 12:37 PM
timbo65
22
Aug 18, 2007 01:15 PM
prerunner
4 Cylinder Engines
Apr 5, 2006 06:29 AM
Mountaineer Boy
Jul 12, 2005 04:12 PM
