Crusty Gas Tank
Old Jan 11, 2025 | 10:04 AM
red21sweep's Avatar
red21sweep
Crusty Gas Tank
Pulled out the seat and took a look at the gas tank. Pretty crusty! I was going to try and restore it, not sure it would be worth it. Couldn't get pictures inside but there is rust everywhere.
Old Jan 11, 2025 | 10:13 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
A localish radiator shop would be able to tank it like they do radiators and clean it very well. From what I can see, it doesn't look like it wouldn't clean up well.
Old Jan 11, 2025 | 10:22 AM
red21sweep's Avatar
red21sweep
Any thoughts on the DIY Eastwood kits?
Old Jan 11, 2025 | 10:27 AM
bmoran4's Avatar
bmoran4
Much easier and less messy to just let the radiator shop boil it out in their tank and call it good. If you insist on an internal coating/seal, do it after the radiator shop has cleaned it - don't do it to cover rust.
Old Jan 11, 2025 | 10:28 AM
red21sweep's Avatar
red21sweep
Thank you
Old Jan 11, 2025 | 12:02 PM
FortyNiner's Avatar
FortyNiner
i used a POR15 tank kit a number of years ago with good results. It was important to do the cleaning on a warmish day and completely dry the tank before applying the sealer.
This may be your only real option - short of replacing the tank - if there isn't a radiator shop able or willing to do the work. The rad shops are mostly gone in many areas.
Good luck with your mission.
Old Jan 11, 2025 | 12:08 PM
red21sweep's Avatar
red21sweep
I called one place and they quotes me starting at $329!!! He told me buy new. I might try the kit. Do it as a learning/Trial and error situation.
Thanks.
Bryan
Old Jan 11, 2025 | 12:11 PM
bmoran4's Avatar
bmoran4
$329? Wow... It should be less than half that unless they are sealing, priming, and finish painting the whole thing too. Hopefully you can get some other quotes.
Old Jan 11, 2025 | 12:13 PM
abe's Avatar
abe
That quote means they don't want to do it.
Old Jan 11, 2025 | 01:15 PM
Setra's Avatar
Setra
Trailering
Thanks.
Bryan
Hello
I recently just bought one at LMC Trucks for $180 new.... for my F2. They also have the sender unit, if needed.
Also was thinking about sealing or other treatments, but with this price it wasn't worth the effort.
Old Jan 11, 2025 | 01:16 PM
red21sweep's Avatar
red21sweep
Originally Posted by Setra
Hello
For $180 it would not be worth the effort!
Old Jan 11, 2025 | 04:49 PM
Grey County Hermit's Avatar
Grey County Hermit
I also used the Por15 kit on my son's '70 F100. I tossed in some nuts and bolts, shook it vigorously for a while to loosen the rust, then followed the instructions to the letter. It worked like a charm, and it had some tiny pinholes that never left puddles but always left the smell of gas in the cab. Mind you, I'm in Canada where prices are double. If I lived in the States I'd just buy a new tank as its a fair bit of work to do the Por15 kit properly.
Old Jan 11, 2025 | 05:14 PM
Fomoko1's Avatar
Fomoko1
This summer I gave my rusty tank a good soaking in menthol hydrate, rinsed and repeated then I used POR15 treatment. A new tank for my 67 F350 was almost $1,000 Canadian funds.
Old Jan 11, 2025 | 07:01 PM
brain75's Avatar
brain75
I pulled my tank 3 times trying to clean it myself (and ran 3 fuel filters trying to keep it clean, a cheap disposable I planned on replacing quite often, and did)... anyhow after the 3rd try i gave up and bought a plastic full size bronco tank and put it between the rails, you can get I think 17 gallon and 33 gallon. I did the 33 gallon and mounted it above the rails under a stakebed (original was a stakebed when I got it). If I had it to do over again, I would advise the smaller bronco tank.
Old Jan 12, 2025 | 08:56 PM
1ruralmailman's Avatar
1ruralmailman
i used the east ood kit 15 years ago on a tractor of mine that was rusty inside.it cleaned out and sealed it real well,it is still being used like the day i got done.
Starliner1955
30
Jul 17, 2024 10:26 AM
Rubiranch
Feb 20, 2022 12:11 PM
SM25
1947 and Older Ford Trucks
Dec 26, 2021 02:26 PM
Ls1500
Dec 24, 2020 06:03 PM
'77F250C
Oct 10, 2019 10:50 PM
