Rear crew cab door lock help
Old Jan 9, 2025 | 07:29 PM
TexasJH's Avatar
TexasJH
Trailering
Hey guys, I have a 96 F250 Crew Cab with power door locks. My question is regarding the driver side rear door lock mechanism.
A few years ago the actuator went out on both rear doors. I was still able to pull the lock tab up and down from the inside, but that got to be a pain so I replaced them.
After doing so, I realized I could still pull the tab up and down manually on the passenger side door, but NOT the driver side door. I still have no idea why, but it simply would not budge. However, both rear door locks worked just fine when I used the power lock buttons on either of the front doors so I didn't think much of it.
Recently we got hit with some cold weather and the locks were frozen pretty stiff. I managed to get onto the driver side front door with the key, but I needed to get into the driver side rear door and the power locks weren't working to unlock the rear, so I reached back and tried to give it a good tug, hoping I might be able to yank it free. Well, I managed to yank it WAY TOO free. The whole threaded rod portion of the lock assembly (the part that the tab that sticks out the top of the door panel screws onto) broke completely off. I can now pull the whole threaded rod and lock tab out the top of the door panel.
What I need to know is; what does that threaded rod connect to inside the door? I'm assuming there's some sort of linkage or joint that secures it to another part of the lock assembly, but I haven't had a chance to take the door panel off and inspect it as it's still too cold outside and I'm sick as a dog. So I'm hoping someone here can give me some insight as to what part failed so I can at least get it ordered and be ready to fix it when the weather warms up a bit.
Thanks in advance!
Old Jan 10, 2025 | 10:40 AM
knottyrope's Avatar
knottyrope
Thanks in advance!
Its an assy from door lock to handle
I had to buy one for same reason
Can pull out seat, door panel and then remove door latch pin via torx bolt through the door and push open door to fix it
Old Jan 12, 2025 | 03:50 PM
TexasJH's Avatar
TexasJH
Trailering
Any chance there is an easier way to open the door? Could it be opened using a slim jim maybe?
Old Jan 13, 2025 | 09:01 AM
knottyrope's Avatar
knottyrope
maybe but i have never tried a slim jim other than the snack food variety
My doo latch would not budge at all and had to do it the hard way
Old Jan 13, 2025 | 06:51 PM
TexasJH's Avatar
TexasJH
Trailering
Weeeeeellll crap. I sure hope I can get it open without having to take the whole seat out! That would suck. A lot.
Old Jan 14, 2025 | 10:20 AM
knottyrope's Avatar
knottyrope
its only a few bolts to take the seat out enough to get the door panel off
squawberryman
Aug 2, 2023 10:48 AM
Spktyr
Aug 2, 2015 08:04 AM
Ciras
Jun 20, 2015 07:50 PM
wanness
Aug 2, 2006 09:42 PM
