Door lock
Old Jul 30, 2006 | 07:54 PM
wanness's Avatar
wanness
Smile Door lock
I have a 1995 F-350, with power door locks. All of the door locks work fine, with the exception of one door. (rear). I cannot get the door unlocked to open it and work on the panel, and trying from the inside is impossible because there is not enough room between the door panel and the seat to be able to remove the panel. Any one ever run into the problem? and if so, what was the solution. Thanks, Bill
Old Jul 31, 2006 | 07:28 AM
mississauga's Avatar
mississauga
Had a similar problem on my car and the rod that moved the lock came off. I kept clicking the the lock on and off and by chance the rod hit the lock and I could open it. Worst case scenario is to remove the seat to work on the door. The other option if you have AAA they may be able to open it .Same situation as locking your keys in the vehicle. Depends on what is broken.
Old Aug 2, 2006 | 09:30 PM
wanness's Avatar
wanness
Thanks for your suggestion. I went ahead and unscrewed the plastic doo-hickey on the lock rod, used a pair of channel locks and finally pulled the lock up enough to open the door.
Old Aug 2, 2006 | 09:42 PM
mississauga
Glad you figured it out.
