Sponsored by: Real Truck
Possible 5r110w automatic transmission issues(again)
Old Jan 9, 2025 | 01:09 AM
Mykah knabe's Avatar
Mykah knabe
So basically, I was driving my 05 f350 v10 with 132,000 miles on it for about 15 minutes. When I accelerated a bit harder than I usually do to get up to a highway speed, it felt like it shuddered from 2nd to 3rd. (I later tested this again, and it shifted fine) also in lower gears, if I consistently push a bit on the gas and let up after a second when trying to maintain a slower speed, it feels like it pulls a little. I'm probably over worried but it doesn't hurt to ask🤷‍♂️. (BTW the fluid was changed with valvoline max life atf about 2,000 miles ago, and when I checked it, it's at the perfect level and it's bright pink, no burnt fluid and no metal shavings on the dipstick.) Also, I'm planning on towing a 23 foot travel trailer in about a month, can the transmission take it fine right now?
Old Jan 9, 2025 | 06:58 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored in the PCM?
Old Jan 9, 2025 | 01:52 PM
Mykah knabe
Nothing on the instrument cluster, nothing in the message center, no codes after scanning the obd2 port. (All temps also good)
Old Jan 9, 2025 | 08:18 PM
Mark Kovalsky
What did you use to read the codes?
Old Jan 9, 2025 | 11:48 PM
Mykah knabe
I don't own one, so I just went to auto zone and borrowed theirs. Just plugged it into the obd2 port under the dash, selected "read codes" and it said: "no codes found"
Old Jan 10, 2025 | 04:51 PM
Mark Kovalsky
That's what an auto parts store reader will ALWAYS read on these trucks. You could have a dozen codes stored and it will tell you there are none.
Get Forscan at www.forscan.org. To read codes you do not need to purchase a license. Their page also shows how to select and OBDII adapter. I bought mine from Amazon for about $30.
Old Jan 10, 2025 | 05:05 PM
Mykah knabe
Oh ok thanks for the info. It seems to be ok right now. Though, the shifts are a little softer then it usually is, but it feels like it's still shifting at the correct time, and it doesn't feel like it's slipping. I tested some harder acceleration on the highway, and the speed increased with the rpms and it shifted smoothly and firmly. Just worried about those soft shifts at low speed/low throttle sometimes.
BrianRich
Jan 20, 2020 03:05 PM
tomrooster-1
May 23, 2014 07:02 PM
Supertommy68
Jun 28, 2013 12:56 PM
SP180
1997 - 2003 F150
Feb 18, 2010 10:21 PM
dave in toledo
Feb 7, 2005 12:44 PM
