I searched and came up empty handed. Anyone else have a Dashcam that is causing a Tire Pressure Monitor System Warning? Every 30 minutes or so while driving with my Rexing Dashcam on I get the warning. The TPMS continues to work for 3 tires but one will not read and then several minutes later it shows back up on the display. The warnings are logged on the FORD APP! If anyone is using a different brand Dashcam that does not cause this issue please share the Make and model along with placement of the Dashcam. Thanks!
It might be a frequency thing. Similar note about frequencies, Ram has a TSB out on certain model year trucks that if a brand and model of spark plug is used and not a factory one, it could cause issues with the TPMS system.
I'm not sure what frequency the trucks use, usually it's 315mhz or I think 433mhz. I know with Dodge stuff, the RFH (radio frequency hub module) is what communicates with the TPMS sensors, might be the same with Ford.
