Dashcam causing TPMS Warning
Old Jan 7, 2025 | 03:05 PM
J&LsF350's Avatar
J&LsF350
I searched and came up empty handed. Anyone else have a Dashcam that is causing a Tire Pressure Monitor System Warning? Every 30 minutes or so while driving with my Rexing Dashcam on I get the warning. The TPMS continues to work for 3 tires but one will not read and then several minutes later it shows back up on the display. The warnings are logged on the FORD APP! If anyone is using a different brand Dashcam that does not cause this issue please share the Make and model along with placement of the Dashcam. Thanks!
Old Jan 7, 2025 | 03:25 PM
Fox-BLUE1's Avatar
Fox-BLUE1
I have a Rove R2-4K up on the passenger side of the rear view mirror. I also have a Rove rear camera on the back window. No issues with TPMS.
Is it the same tire over and over again? Maybe a bad sensor in that tire? Do you have the issue if you drive with your camera powered off?
Old Jan 7, 2025 | 09:20 PM
wearenh's Avatar
wearenh
Originally Posted by J&LsF350
... Rexing Dashcam on I get the warning. If anyone is using a different brand Dashcam that does not cause this issue ...
I use a Rexing V1 and I do not get the TPMS error
Old Jan 8, 2025 | 02:35 PM
J&LsF350's Avatar
J&LsF350
Thanks for the reply it is not the same tire and it does not happen when the Dash Cam is off.
Old Jan 8, 2025 | 02:37 PM
J&LsF350's Avatar
J&LsF350
This is the same Dash Cam I am using. Mine is mounted immediately to the left (drivers side) of the rearview mirror. Where is yours mounted?
Old Jan 8, 2025 | 04:39 PM
wearenh's Avatar
wearenh
immediately to the right of the mirror ...and for power I am using this mirror tap harness
Old Jan 8, 2025 | 07:20 PM
Frdtrkrul's Avatar
Frdtrkrul
It might be a frequency thing. Similar note about frequencies, Ram has a TSB out on certain model year trucks that if a brand and model of spark plug is used and not a factory one, it could cause issues with the TPMS system.
I'm not sure what frequency the trucks use, usually it's 315mhz or I think 433mhz. I know with Dodge stuff, the RFH (radio frequency hub module) is what communicates with the TPMS sensors, might be the same with Ford.
Tim Murray
Dec 26, 2024 01:06 PM
Anthony Hernandez
2015 - 2020 F150
Mar 25, 2021 05:29 PM
Tom
2015 - 2020 F150
44
Nov 28, 2017 08:39 PM
cjensen68
Crossovers
Jun 29, 2014 02:48 AM
fred_79f250
General Automotive Discussion
23
Jan 11, 2008 10:32 PM
