Caster
Old Jan 7, 2025 | 02:09 PM
NCShooter00's Avatar
NCShooter00
Caster
'03 EX 4x4
Recently my worn out steering box was replaced by local shop with a Redhead I bought direct from RH. I didn't get a copy of my steering settings until today. I forgot to get it when I picked up the truck.
I've read quite a bit here about Caster or the lack of in these trucks. Heres a copy of my before & after. Looks like they set it back to what it was originally 3.1°
I guess my question would be, should I look at adding in the "Caster sleeve" (not sure what they're called) in order to get 5°? Still getting used to the Super Duty wander if you will. It's not terrible but seems it could be better.
Old Jan 7, 2025 | 06:45 PM
John in OkieLand's Avatar
John in OkieLand
yours is about where mine is today, and I have having it increased next week to ~5*
I bought some shims that were suggested to me.
this should add 2* or so... my Alignment guy knows these trucks, says 4.5* should make it good.
I ordered both lengths of bolts, don't know what is needed. cheap enough.
Old Jan 7, 2025 | 07:02 PM
NCShooter00
Awesome. Keep me posted on the results. These are the ones I've typically seen.
Old Jan 7, 2025 | 09:04 PM
John in OkieLand
I just assumed that those adjusters are Maxxed out, because when the alignment guys were doing my truck 2 years ago, I asked if that is all they could make it go.
so I ordered the shims as an option
riderboy1961
Jan 13, 2025 02:39 AM
herojeep
Jan 29, 2017 02:33 PM
hkaiser83
Apr 14, 2011 08:10 AM
merccougar93
15
Sep 1, 2010 09:37 PM
Pappys53
May 7, 2009 01:25 PM
