Upper oil pan seal fix
Old Jan 3, 2025 | 03:43 PM
speakerfritz's Avatar
speakerfritz
lots of labor
https://youtu.be/qD67GbJWhzU
speakerfritz
Old Feb 11, 2025 | 03:15 AM
slyluna's Avatar
slyluna
8th Gear
I just got quoted 40 hrs of labor $7500 for the job. That video says 13-14 hours labor?
Old Feb 11, 2025 | 09:22 AM
jollyrogr's Avatar
jollyrogr
Made it look easy. Some of those bolts look like a real PITA to R&R. Doesn't look like something you'd want to attempt without a lift.
Old Feb 11, 2025 | 11:21 AM
JoeUser's Avatar
JoeUser
Seems like they would've designed some kind of bolted-on crossmember type of system, to allow access to the lower engine without have to lift the entire body. Support the engine and transmission, unbolt crossmember(s), do the work, then reassemble. Unless the structural integrity would be compromised?
Just seems like two engineering teams had no cross-communication while designing the truck, crazy...
Old Feb 11, 2025 | 11:24 AM
speakerfritz
I gad this done on my truck as part of warranty work.
they did it in two days.
granted, the shop I went to was probally experts at this and knew how to get it done quickly.
Old Feb 11, 2025 | 02:29 PM
acdii's Avatar
acdii
Here I thought you decided to replace it with a RAM. LOL
It appears that removing the body is a Ford thing since all their Pickups require it to really be able to work on the engine.
Old Feb 11, 2025 | 03:32 PM
speakerfritz
Truth be told…if I had it to do all over again…I think I would have bought a RAM….but at this point…I think I’m in too deep to change directions.
Old Feb 11, 2025 | 07:34 PM
krc0864's Avatar
krc0864
Rerouting my CCV fixed my upper oil pan gasket. Been there and done that with a 6.7 Cummins and I will never own another Ram, not trying to start a Ram vs Ford war here. I'm the one that started the massive original killer grid heater thread over on the other forum when mine failed.
Old Feb 12, 2025 | 09:54 AM
acdii's Avatar
acdii
Ram, buy a new one, and get an old one at the same time, Ram, the design that never changes. Hey look, you bought your dads old truck! What? Its brand new? o'rly? Only way to tell the age of a Ram today is by the amount of rust on it.
ok I'm done rambashing
for now.
Old Feb 12, 2025 | 11:13 PM
jollyrogr's Avatar
jollyrogr
for now.
LOL
If you stand next to a Ram you can hear it rusting.
Hyakkimaru
60
May 14, 2024 05:13 PM
scraprat
Modular V10 (6.8l)
Jun 3, 2010 05:32 PM
helpfulguy
Mar 28, 2006 08:26 AM
wgw
Feb 28, 2005 03:55 PM
