Ford 360 fe dipstick help
Old Jan 3, 2025 | 12:00 AM
brevikF's Avatar
brevikF
Trailering
I recently put a 360 in my 67 f100, the oil dipstick I have enters through the block and the new motor has a oilpan entry for the dipstick. I am having a hard time finding a dipstick that fits my needs. Anything helps, thank you!
Old Jan 3, 2025 | 12:16 AM
Green72F250's Avatar
Green72F250
Here is a thread that talks about the dipsticks with the part number. This is for the 2WD not the 4WD which had a different dipstick. I see these listed on e-bay every once in a while. Dipstick FE 390 ( and Oil Pan ) - Ford Truck Enthusiasts Forums
Old Jan 3, 2025 | 08:00 PM
1browski's Avatar
1browski
Does the engine have a front sump or rear sump?
Old Jan 3, 2025 | 08:26 PM
brevikF's Avatar
brevikF
Trailering
It is the rear sump
Old Jan 4, 2025 | 05:14 PM
1browski's Avatar
1browski
The rear sumps are normally on a 4wd truck. Did you swap the 360 in and what was the original engine? If it was a 352, the oil pan and dipstick should swap.
Old Jan 4, 2025 | 05:36 PM
brevikF's Avatar
brevikF
Trailering
I just swapped in the 360 it had a 352 but the 352 had the dipstick through the block so I can't swap it over.
Old Jan 4, 2025 | 06:39 PM
JEFFFAFA's Avatar
JEFFFAFA
What did the newer engine come out of? 2X 1browski, sounds like it was a 4X4. have you mounted the engine? The rear sump may hit the crossmember.
1966 F100 4X4 352, 1967 F100/250 4X4 352, and 68/72 F100250 4X4 360 oil pan was part number C7TZ6675E. Ford noted this pan came with tube part number C7TZ6754A and dipstick part number C7TZ6750B.
***** THIS IS IF IT CAME OUT OF A 4x4*******
I only find one NOS dipstick out there. It's at:
NOS Only
Part Number:
C7TZ-6750-B
Description:
Price:
Request Pricing
Quantity:
Seller:
NOS Only View Profile
Phone:
(408) 227-2353
*Tell them you saw it on Rear Counter
Email:
Send Seller a Message
Location
San Jose, California
Old Jan 5, 2025 | 09:04 PM
1browski's Avatar
1browski
On my 72 f250 4x4, the PO had put an engine from a 2wd in it. That being said, I have never seen the 4x4 pan and dipstick in person, only pics. The hole in the block should still be there, I imagine. I doubt Ford cast 4wd blocks and 2wd blocks. Is there a plug in the block and if so, you could use the 2wd setup. They are definitely easier to find. Also, mentioned by JEFFFAFA, the rear sump oil pan will hit the cross member on a 2wd.
dcc73
Sep 23, 2016 08:47 AM
F-adams
WTB - Ford Trucks & other vehicles
Aug 17, 2016 09:33 PM
arobe06
Apr 27, 2010 10:34 AM
