front spring model
Old Jan 4, 2025 | 01:51 PM
Nonofordf150's Avatar
Nonofordf150
so is it possible to delete it?
Old Jan 4, 2025 | 01:58 PM
Junktownbill99's Avatar
Junktownbill99
It's possible, but I wouldn't, you would have to delete a main spring to see any difference, the overload doesn't do anything until the pack is compressed. These were designed to sit higher in the rear, yours doesn't look overly high as is.
Old Jan 4, 2025 | 02:50 PM
Nonofordf150
ok it works I'll leave it like that then.
what main spring are you talking about.
Old Jan 4, 2025 | 02:53 PM
Junktownbill99
I'm talking about the four springs in the pack actively holding the truck up.
Old Jan 4, 2025 | 02:55 PM
Nonofordf150
Okay, I was just thinking of removing the last blade and that was it.
ok then thanks for the information, I'll leave it like that.
Old Jan 4, 2025 | 02:56 PM
Nonofordf150
I thought the last blade was mounted additionally.
Old Jan 4, 2025 | 03:01 PM
Junktownbill99
If you remove it, you will see zero difference in how high it sits.
Old Jan 4, 2025 | 03:05 PM
Nonofordf150
ok it works then thank you.
Old Jan 5, 2025 | 09:15 PM
samuel4wolfpack's Avatar
samuel4wolfpack
The SPR code on my 1996 F250 4x4 HD is 64F.
Old Jan 6, 2025 | 06:33 AM
rla2005's Avatar
rla2005
Spring Code E shows up as Ford Part# E0TA-5310-EC. I have not found any aftermarket spring supplier that lists that part number equivalent. If you do pursue a replacement I would look for something that does not provide a lift, just restore the factory ride height. Getting these twin-I-beam suspensions aligned gets tricky when you start adding a lift, even a small one.
Old Jan 6, 2025 | 06:37 AM
Nonofordf150
Thanks a lot for the info, so I should upgrade the rear too?
for the springs what reference in moog or other can I put to keep the origin at the front?
Old Jan 6, 2025 | 06:46 PM
Junktownbill99
No.
Rla didn't find an aftermarket equivalent to your specific springs. Your options are OEM, or an aftermarket with similar specs.
Old Jan 7, 2025 | 12:26 AM
  #28
Nonofordf150
ok thank you very much for the reference you huge, I will check with that.
many thanks.
Old Oct 18, 2025 | 11:26 AM
  #29
Nonofordf150
Hello,
I'm back on the new one.
I just replaced my front shock absorber springs with Moog CC824s recommended by Moog. The height is correct. Will it settle a little more?
The steering wheel has moved, but the car drives very well. I need to adjust the toe and see if the camber has moved, because visually, it doesn't look very positive.
Should I drive it for a bit longer to settle before making the adjustment, or not? I drove 6 km.
Thanks.
Old Oct 18, 2025 | 11:31 AM
  #30
Junktownbill99
Moog CC824 is a spring, not shock absorber. I installed them on my f150 to pick the front up a touch.
Yes, drive it for longer to settle the springs.
