Vibration under load
Old Dec 31, 2024 | 06:13 PM
jacoby111's Avatar
jacoby111
4wd Low
My 1993 f150 has a vibration that feels like it’s coming from under the seat, possibly further back, when I accelerate at any speed usually going up a hill but sometimes on flat ground. Any ideas what it could be? Wheels unbalanced? I can accelerate on flat ground at high speeds above 60mph and it’s non existent.
Old Dec 31, 2024 | 06:26 PM
Junktownbill99's Avatar
Junktownbill99
Inspect the U-joints
Old Dec 31, 2024 | 06:46 PM
jacoby111's Avatar
jacoby111
4wd Low
I read a thread on here that said to inspect u joints you should apply parking break, chalk tires, put in neutral and then check joints for any movement. Is this correct?
Old Dec 31, 2024 | 06:59 PM
Junktownbill99
Also disconnect the driveshaft and feel how stiff they are.
Old Dec 31, 2024 | 09:32 PM
Conanski's Avatar
Conanski
Could be the carrier bearing if it has a 2-pc driveshaft, could also be dried out U joints in the driveshaft. The driveshaft has to be removed to inspect for these issues, it's not good enough to simply shake it looking for movement.
Old Jan 1, 2025 | 11:42 AM
manicmechanic007's Avatar
manicmechanic007
To check the u joints you jack the truck up and put it in neutral on jackstands or a hoist
Then roll the driveline(s) over, back and forth looking for any looseness or movement in the u joints
In your case while rthe truck is jacked up and you are checking the u joints, check the rear axle pinion for being loose on the rear end
That is common, when the pinion bearings get worn, the rear yoke will be loose on the pinion gear
BigWhite2020
Sep 1, 2022 11:54 AM
blackbeautyf250
Apr 4, 2013 05:22 PM
mjs
Jun 21, 2005 09:46 AM
mowreyp
2004 - 2008 F150
Apr 17, 2005 04:02 AM
pipercoal
Jan 5, 2005 09:54 PM
