Does this sound right?
Old Dec 30, 2024 | 12:13 PM
Outdoorboy26's Avatar
Outdoorboy26
Hey guys. 1st diesel, a 2000 F250 7.3 with 126,000 miles. The video here shows a noise, but I think I've determined this is just normal belt sound. I loosened the belt, gave the pulleys a spin and it's not those bearings. The belt looks to be in great shape. So I guess I'll live with it. It just seems loud ... like you hear hear it a distance from the truck. Just wanted to get the forum's opinion on this. Here's the link:
https://youtube.com/shorts/AT3xgeWm3Wk?si=tBc0_RevzkK070RG
Old Dec 30, 2024 | 12:26 PM
kenn_chan's Avatar
kenn_chan
https://youtube.com/shorts/AT3xgeWm3...c0_RevzkK070RG
Sounds like my truck but at my age the ears are pretty worthless to be honest.
Old Dec 30, 2024 | 03:43 PM
John in OkieLand's Avatar
John in OkieLand
pretty much sounds like mine, except for an occasional Rumble? that I can't pinpoint
Old Dec 30, 2024 | 08:12 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Could rub the belt lightly with a candle or soap (engine off ofc) and see if the sound changes.
Old Dec 30, 2024 | 08:33 PM
INFRNL's Avatar
INFRNL
Sounds like a bearing failing...alt or possibly the ac pump but it could be something else. Definitely sounds like a bad bearing to me though. I'm pretty sure that's not normal but now you have me wondering...i'll have to go fire mine up
Old Dec 30, 2024 | 08:36 PM
JoshHefnerX's Avatar
JoshHefnerX
Mechanics stethoscope, they're cheap. Just keep them out of any moving parts. Works great for finding noise.
Old Dec 30, 2024 | 08:44 PM
INFRNL's Avatar
INFRNL
that, light squealing noise is definitely not normal...I just went and fired mine up. It's most likely a failing bearing. You will have to pinpoint it like josh mentioned. You may also be able to take the belt off and spin the other items you missed and see if you can feel anything. I'm guessing if the belt is off, then the noise goes away
Old Dec 31, 2024 | 12:10 AM
kenn_chan's Avatar
kenn_chan
Talking
i have done that before..... trying to listen to a belt fed emissions pump on a rotary...snatched the stethoscope right out of my hands and off my ears...
Old Dec 31, 2024 | 06:47 AM
BillyBob69's Avatar
BillyBob69
I am thinking either idler pulley or tensioner. Remove the belt and give those a fast spin. Even by hand you may be able to hear something. Both are cheap and easy to replace.
Check the others with the belt off as well. AC pump, alternator... check for in and out play on the pulleys as well.
Old Dec 31, 2024 | 08:20 AM
RacinJasonWV's Avatar
RacinJasonWV
Thats not the way my dad taught me.
But I’m not gonna be responsible for accidents by telling people how it’s done at my house.
Old Dec 31, 2024 | 09:11 AM
RA101725's Avatar
RA101725
Banned
Spray some water on the smooth side of the belt and see if it goes away. And/or remove the belt and start the engine and see if the noise goes away
Old Dec 31, 2024 | 09:26 AM
RA101725's Avatar
RA101725
Banned
or a slight deflection in the belt causing it to rub on the edge of a pulley. I had this problem with a worn out water pump pulley that was allowing the belt to rub up on the inside edge of the pulley. Also the power steering pulley can cause a mis-alignment if it’s pressed on too shallow or deep.
Old Dec 31, 2024 | 10:16 AM
Pikachu's Avatar
Pikachu
[QUOTE=Brandonpdx;21446569]Spray some water on the smooth side of the belt and see if it goes away./QUOTE]
^^^^ This. And take a good, long look at the tensioner and other pulleys to make sure they're well aligned.
Old Dec 31, 2024 | 10:24 AM
Outdoorboy26
What does water on the smooth side of the belt do?
Old Dec 31, 2024 | 12:11 PM
Pikachu's Avatar
Pikachu
Pulley wear and misalignment can make the belt chirp on the smooth side as the belt gets slightly deflected then "skates" back into alignment. If wetting the belt stops it, check the pulleys to make sure they're all parallel to each other.
