Does this sound right?
Old Dec 31, 2024 | 12:18 PM
Outdoorboy26's Avatar
Outdoorboy26
Originally Posted by Pikachu
Pulley wear and misalignment can make the belt chirp on the smooth side as the belt gets slightly deflected then "skates" back into alignment. If wetting the belt stops it, check the pulleys to make sure they're all parallel to each other.
ah. Thank you.
Old Dec 31, 2024 | 12:39 PM
INFRNL's Avatar
INFRNL
k...everyone place your bets while we wait for the results
INFRNL's Avatar
INFRNL
Originally Posted by BillyBob69
I am thinking either idler pulley or tensioner. Remove the belt and give those a fast spin. Even by hand you may be able to hear something. Both are cheap and easy to replace.
Check the others with the belt off as well. AC pump, alternator... check for in and out play on the pulleys as well.
I thought he mentioned doing this in the OP...maybe I'm mistaken
Old Dec 31, 2024 | 12:42 PM
Outdoorboy26
I gave them a weak spin as my dad held tension off the belt. Ill remove the belt and give them a good hard spin now.
Old Dec 31, 2024 | 12:50 PM
INFRNL's Avatar
INFRNL
sounds good. as others mentioned...take your time and check everything with a pulley out
Old Dec 31, 2024 | 01:48 PM
Outdoorboy26
Well, I fired it up to spray some water on the belt and it's running beautifully without the noise. Ha. Wouldn't you know it. Last Thursday it sounded fine. Friday to yesterday (Monday) it made that belt sound. Today sounds quiet and brand new. Who knows? Ha
Old Jan 1, 2025 | 06:24 PM
RA101725's Avatar
RA101725
Banned
Look closely at how well centered the belt is riding on the water pump pulley. Also look closely at the two belt tensioner halves. I've seen them go bad where the two halves start to become separated also causing a belt mis-alignment when the front part holding the pulleys droops down.
themdgx
1983 - 2012 Ranger & B-Series
Sep 1, 2012 11:01 AM
bduemig
Aug 19, 2010 10:08 PM
Butl85
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sep 7, 2007 07:29 AM
dcara
Aug 31, 2007 01:24 PM
FordCowboy2000
1997 - 2003 F150
Jul 17, 2003 12:09 PM
